sandfantom
have a 2001 Toyota 4runner with a 3.4 v6, auto trans, 4x4. I am in the process of installing a Bulldog remote starter. I got the remote starter in and was haveing problems with the remote recycling after a no start. No bad at this point, just annoying. I decided to try and make the rear window roll down with the remote. When back probing with a power probe to the connector I thought was the window circut, I believe I back probed to the ECM. I am not sure about this as I don't have the correct wiring diagram to tell me what this wiring harness is for. The wiring connector that I was back probing is on the drivers side down by the kick pannel. It has six wires. One is red w/yellow tracer, green w/black tracer, heavier black wire, etc.....when I back probed the green w/black tracer the "check engine light", O/D off light and the "cruise" light all come on on the dash. Maybe these wires go to the vehicle speed sensor and/or trans.
As of now, the truck will not start. Every thing else works. The engine cranks over fine. I have no spark. The "check engine light" does not come on at all. I cannot retreive any codes or get any communication with my Snap On scanner with the OBDII chip in it. I think that this truck has a pass key system, but when we bought it, it didin't seem to work. I have a duplicate key with no plastic housing that would start the truck. Could the pass key system be the problem and working now?
I have removed all of the remote starter thinking that this might be the problem. Still no workee. I have checked all of the fuses that I can find, all are good.
I am hoping the ECU is not bad, but maybe you can tell me if you think it is. Is there a way to test this ECU to make sure it is faulty or not??
Thanks for any info you can give me
