Would 16" Konig Offroad fit?
Does anyone know if 16" Konig offroad wheels would fit on non-lifted, stock tire size truck? I really like them and are thinking of getting them and some new tires when I have some more money... :naughty:
Depends on the backspacing. If they are anywhere between 3.5 to 5" of backspacing, you should be ok. The higher the number of backspacing, the more they will suck into the truck.
What is backspacing by the way? It says 0mm backspacing on their website but I don't know how to interpret that because I don't know what backspacing is.:ybrick:
Its the distance between the mouting surface and the inner facing lip of the rim. If you had a 10" wide rim, a wheel with 5" backspacking would mean the mounting surface was positioned directly in the center of the rim. The more backspacing (number going higher) the more "sucked-in" the wheels go.
