Would you guys with the Pro be interested in a levelling spring?
The Standard coilover Eibach, King, or Wheeler spring to those specs will have flat ends.
According to eibach they'll have to get a new pro in their shop to test it because they don't make their springs with the flat top and bottom. Kings only has a 3" ID x 14" so if I have to go any route it will be the Kings.
Maybe I'm confused. Are you asking for a '16 like your forum name implies, or a '19 Pro? What year pro suspension do you have?
You are. I had a 2016 trail but I now have the new pro that comes with the fox setup. The only difference that I can tell between the Bilstein spring and pro spring is the top and bottom are flat.
Ah gotcha. Now my Bilstein 6112s are flat on both ends. Just like a traditional coilover spring. Your '19 Pros are different?
Nope they're the same. Eibach 3.0" ID Springs | AccuTune Off-Road they look the same other than the color
the Bilstein pro has a certain way the bottom needs to go. The new fox springs can just be put on(I assume you don't want to put it upside down). Now I could be wrong the the springs but when I looked at them on mine they do look a little different.
H.Sikina
