WP/TB life
z4r
New here, great site.
Last Saturday, my wife came home and saying there's coolant dripping from our 98 (3.4L) out of the blue. I checked and it was on the driver side, right around the alternator bracket that mounts to the block. I figured it had to be the water pump, but it's odd that it's not dripping from the center.
Anyway I open the top of TB cover, and surprised the belt looked almost new and nothing was wet there. Only after I dismantled everything that I can see it's the water pump leaking (wet weep hole, and gasket seems to be gone too).
I was planning to do the change, but didn't think it would force my hands. How can a belt look new and pump is gone? Truck has 200k miles (got it 50k ago with unknown history - single previous owner though), but I was hoping for a bit more time.
I guess water pump life is a hit or miss. Due to the timing, I got WP (GMB) from Advance auto, hopefully it'll last.
The old water pump has few markings (not OEM). I'll see if I can upload a pic so someone might be able to id it.
Couple of things learned if you're doing it on your own:
1) Get that special tool that compresses the hydraulic tensioner in place, or you have to remove PS pump, AC compressor and everything else to remove the tensioner. Took a while since I don't have that tool.
2) Need a puller to remove the crank pulley. Two holes in there, but none of my bolts can catch it. Eventually got a loaner tool for that (6 inch or bigger puller).
Other than that, I got it done with basic set of sockets/adapters without any power tools.
If you have not owned the 4 runner since new, the previous owenr may have just changed the TB and not the H20 pump. Why? The only logical, and it is a stretch for me, is to save $$$. I have heard of water pumps failing, but cannot remember one single instance in which a timing belt has broken.
Some pics of the water pump. Very little marking on it. In one pic you can see a logo next to the roller. It still rolls very smooth, no play at all (I even struck it with heavy blow, and nothing would budge).
Is this the OEM water pump (Aisin)? Might it be original? The logo does look like an A inside of a circle.
If it's OEM, then you're probably right in that it was never changed and survived 200k miles. Pretty good in that case.
delislerebecca
