WTB 99 Highlander - Finders get paid!
gooserunner
UPDATED
Ladies and gentlemen,
I am sick of looking for a 1999 Toyota 4Runner Highlander Edition. So, I have decided to place a finders fee out there for leads. $100 to the person that finds the 4Runner I end up buying.
Has to be black
Prefer gray interior
Prefer Auto Transmission
Rear locking axle a huge plus
No 2000 or 2001. 1999 only. After spending a lot of time on autotempest.com and adhuntr.com, these sights are never truly running correctly, and I started noticing that they don't pull all of the 4runners in. For instance, I searched buffalo, NY for one a few days back. with autotempest and adhuntr, a 4runner did not pull up on either, and i tried searching 4runner, 4 runner, 4-runner, and forefunner/forrunner/fourrunner.
There is a great example of what I am looking for from Forum member ADH8796
No, i'm not looking for a runner post-build (Though its an impressive build and turned out great). I am looking for it in it's stock form. I have $8000 set aside for the car, and another bit for my build. Mileage is not a huge issue at this point, but rust is. Aside from the bumpers, which are usually bitten by rust, I am hoping to find one with no rocker cancer.
If ANYONE can help, Please. I am getting impatient, and running out of time. Going to Tennessee in a few weeks, and need to get the ride, mod it, and take it out with my friends for a bachelor party weekend of wheeling and casinos.
I'll Save you some time since I printed this out yesterday. I've tried to talk my brother into buying this but he's OUT. Would like to see this go to a forum member....
From Toyota Owners website.
09/27/2012 Dealer Ira Toyota 99,918 Repair Order Number: 1081427
PERFORM TRUCK CONVENTIONAL OIL AND FILTER CHANGE SPECIAL (MODELS: TUNDRA, SEQUOI
1031137 20127 17-Dec-11 true 12/17/2011 Dealer Ira Toyota 95,660 Repair Order Number: 1031137
PERFORM 26-POINT INSPECTION OF VEHICLE. ADVISOR WILL ATTACH TOP COPY OF FORM TO, FRONT BRAKES NEW, REAR BRAKES 4MM, ***TIRES ARE 10/32***, SERVICE - 90,000 MILES OR 72 MONTHS, REPLACE TIMING BELT, REPLACE SPARK PLUGS, INSPECT BRAKE LININGS/DRUMS AND BRAKE PADS/DISCS, INSPECT BRAKE LINES AND HOSES, INSPECT BALL JOINTS AND DUST COVERS, INSPECT DRIVE SHAFT BOOTS, INSPECT EXHAUST PIPES AND MOUNTINGS, INSPECT STEERING WHEEL, LINKAGE AND BOOTS, INSPECT STEERING GEAR BOX, INSPECT AUTOMATIC TRANSMISSION FLUID, ROTATE TIRES, INSPECT TRANSFER CASE OIL, INSPECT FRONT DIFFERENTIAL OIL, INSPECT REAR DIFFERENTIAL OIL, INSPECT DRIVE BELTS, REPLACE ENGINE OIL & OIL FILTER, REPLACE ENGINE AIR FILTER, LUBRICATE PROPELLER SHAFT, REPLACE ENGINE COOLANT, RE-TORQUE PROPELLER SHAFT BOLT, INSPECT FUEL TANK CAP GASKET, INSPECT FUEL LINES AND CONNECTIONS, FUEL TANK VAPOR VENT SYSTEM HOSES, FUEL TANK, PERFORM DEALER RECOMMENDED POTHOLE SPECIAL ( 4 WHEEL ALIGNMENT AND 4 WHEEL BALAN, DEALER RECOMMENDED NEW ENGLAND CONDITIONS SERVICE (4WHL BRAKE SERVICE / THROTTLE, CUSTOMER REPORTS PARKING BRAKE DOES NOT HOLD. ADVISE, CUSTOMER REPORTS LEFT REAR LOWER SEAT CUSHION IS LOOSE. ADVISE, E-BRAKE PIVOT REPLACED ONE SIDE, PAD KIT - FRONT (W/O HARDWARE) - REPLACE, WIPER INSERT (REAR) - REPLACE, REPLACED BROKEN SWAY BAR END LINK. RECHECK GOOD, EXHAUST TAIL PIPE - REPLACE
0967865 20127 08-Jan-11 true 01/08/2011 Dealer Ira Toyota 88,120 Repair Order Number: 0967865
CUSTOMER REQUESTS AN OIL AND FILTER CHANGE.CHANGE OIL AND REPLACE FILTER WITH A, REAR BRAKES 3MM FRONTS 6MM, ***TIRES ARE 12/32***, THANK YOU, RESET MAINTENANCE LIGHT, ODOR WAS DETECTED-BUT SOURCE NOT DETERMINED-CUSTOMER SHOULD SCHEDULE AN APPT. FO, DECLINED FOLLOWING WORK, REPLACED R/S BRAKE LIGHT BULB, REPLACED REAR WIPER INSERT
0919919 20127 29-May-10 true 05/29/2010 Dealer Ira Toyota 80,650 Repair Order Number: 0919919
REPLACE STARTER, DO NOT PERFORM 27 POINT COURTESY INPECTION, TECH RECHARGED AC SYSTEM
0915401 20127 08-May-10 true 05/08/2010 Dealer Ira Toyota 79,973 Repair Order Number: 0915401
BATTERY, SEE TECH NOTES, OIL CHANGE SPECIAL.CHANGE OIL AND FILTER., ***BRAKES ARE 5 MM***, ***TIRES ARE 7/32***, STEERING RACK IS LEAKING MUFFLER IS LEAKING DUE TO RUST, THANK YOU, ., RESET MAINTENANCE LIGHT
0861302 20127 19-Aug-09 true 08/19/2009 Dealer Ira Toyota 76,387 Repair Order Number: 0861302
CUSTOMER REQUESTS A 15,000 MILE SERVICE INTERVAL, *****CUSTOMER DECLINED TIRE ROTATION*****, ***BRAKES ARE 4MM***, ***TIRES ARE 11/32***, VEHICLE CHECKED OUT IN GOOD CONDITION AT THIS TIME, THANK YOU FOR HAVING YOUR VEHICLE SERVICED AT IRA TOYOTA OF DANVERS.IT WAS MY PL, RESET MAINTENANCE LIGHT, TECHNICIAN REPLACED THE TIMING BELT, ACCESSORY BELT, AND WATERPUMP.
0797205 20127 06-Sep-08 true 09/06/2008 Dealer Ira Toyota 69,955 Repair Order Number: 0797205
70,000 MILE MAINTENANCE, CHANGE OIL & FILTER, CHECK ALL FLUIDS, LUBE HINGES, ROT, PERFORM 27 POINT COURTESY INSPECTION, RESET MAINTENANCE LIGHT, FOUND TRANSFER CASE LEAKING,REMOVED TRANSFER CASE DISASSEMBLE AND RESLEAEDTRANSF, THANK YOU FOR SERVICING YOUR VEHICLE WITH IRA TOYOTA. F YOU ARE NOT COMPLETELY S, REPLACED RIGHT REAR E-BRAKE PIVOT
0721582 20127 20-Aug-07 true 08/20/2007 Dealer Ira Toyota 65,307 Repair Order Number: 0721582
65000 MILE SERVICE OIL CHANGE, FILTER, ROTATE TIRES, INSPECT BRAKES., COURTESY INSPECTION, NEXT SERVICE DUE AT 70,350 MILES OR BY DECEMBER 2007. THANK YOU!, BALANCE 4 WHEELS, CUST REQUEST 4 WHEEL ALIGNMENT
0661862 20127 10-Nov-06 true 11/10/2006 Dealer Ira Toyota 60,423 Repair Order Number: 0661862
60,000 MILE SERVICE 4X4, CHECK ENGINE LIGHT CODE P0171, FAULTY MASS AIR FLOW SENSOR, REPLACED SENSOR, WIL, RESET MAINTENANCE AND TIRE LIGHTS, COURTESY INSPECTION, REPAIRED RIGHT REAR TIRE, REPLACED POSITIVE BATTERY CABLE END, REPLACED FRONT CALIPER GUIDE PINS, BALANCE 4 WHEELS, CUST REQUEST 4 WHEEL ALIGNMENT
0619471 20127 21-Apr-06 true 04/21/2006 Dealer Ira Toyota 57,837 Repair Order Number: 0619471
REPLACED LEFT PARKING BRAKE PIVOT AND PERFORMED REAR BRAKE SERVICE, $30.95 CHANGE OIL AND FILTER,CHECK ALL FLUIDS,SET TIRE PRESSURE, SET ALL TIRE PRESSURES, ****CUSTOMER DECLINED 60,000 MILE MAINTENANCE****, RECOMMEND REPLACING TIMING BELT AND ACCESORY, FREE CAR WASH, COURTESY INSPECTION
Examples
Looking for the matte black fender flares like these
Found one...
Highlander 1999. It has to have the matte black fender flares. I'll post a pic as an example soon
I found what you are looking for. It is not listed yet online because he just got it today. It has everything but no locker. Miles are at 175. Other than that it is VERY NICE!!!!
Blue
PM me for further. I have the email from him with pictures for you to look at!!!! :bigok:
Blue
Can't do that many miles. Too close to a cylinder rebuild (potentially). Thanks for the lead tho!
You're out of your mind. There's no difference between 140K miles and 175K miles. If its a good truck with good records, don't pass it up. If it doesn't have good records but its priced right, you still can't go wrong.
Out of his mind ?
No difference but 35,000 miles , I don't blame him I wouldn't buy a truck with 175k unless it was a sweat deal . 100k was my limit when I was buying a 3rd gen .so I must be totally crazy !
I would have about 178k on it by the time I drove it home too. If it was $5000 I would get it, and do an engine swap with the extra cash. But most likely the guy wants $7000 and the. I'll have to put another $2-3k in repairs, which leaves even less to accessorize the car. I just lost out on a 1999 highlander with locker, one owner with clean car fax and 106,000 miles for $6500. That WAS a deal. So I'll wait for something like that to come around.
engine swap at 178k miles?? thats just broke in! :jaw:
True...Hopefully. I know I might have to get the belt and pump replaced, possibly injectors and such. But I dont want to get a 4runner and dump a bunch of money into unknown repairs over the first couple years. I am planning some mild mods, and would like to knock them out right away. I know Ill have unexpected repairs down the road, but need to try and avoid them right off the bat.
I found this one, I know it has high miles, but its not a bad price and has everything else, and is in great condition
1999 Toyota 4Runner_SR5 Highlander_5spd
Now that is exactly what i am looking for... except about 100,000 less miles (But the same Price!). Kidding.
I found this exact same car in Chicago, but mileage is unknown. Selling for $8000. If its close to 100,000 miles, I will probably grab it. Dealer wont email or call me back though.
This one doesn't have the hood scoop, so it may be a Limited, but the price seems decent for the miles and condition.
1999 Toyota 4runner
That's not bad. I'll run a carfax on it tomorrow to see if it has been wrecked. The sport hood oem replacement is much more expensive, so this thing may have been in an accident. I'll follow-up after I get the vin. Thanks!
It's your truck, buy what you want. But you're getting too hung up on mileage. It really doesn't mean a whole hell of a lot of these trucks. Find one with good maintenance history and don't second guess yourself.
erinobr2000
