x-reas question
TheycallmeDOC
About to pull out the x-reas and replace it with the toytec/bilstein set up all the way around. Is it really necessary to get all 4 wheels off the ground to take out the x-reas? its leaking so i wont be saving it nor do i care if it gets damaged further. i was thinking i could just jack it up and release the shock at the coupling thats about 8-10" down the hydraulic line coming that comes out of the shock body. i might not even remove the reservoirs and tubing till later down the road.
No issues doing it that way. It all tires aren't in the sure you may make a mess with fluids, other than that it doesn't matter what you do since the system is already trash.
turbomikee
