He asked how does he know if his truck has it, not what it does.r32 said:"Standard on the Sport Edition and optional on the Limited is a new diagonal-linked shock system developed by Yamaha, dubbed X-REAS. The system was developed and implemented earlier on Supras and has been updated and redesigned specifically for the 4Runner. X-REAS essentially cross-links front and rear shock reservoirs on opposite sides of the vehicle. A central control absorber contains a free piston that pushes against a low-pressure nitrogen charge. An orifice senses motion across the vehicle and varies dampening to the appropriate shocks.
Think of it this way. As the truck rounds a curve to the left, the rear, driver side shock is relieved while the front, passenger side is increased. This helps to keep the truck more level and in control, instead of diving to the front, passenger side. We got the chance to wail on the 4Runner through some nice country road twisties and we can tell you that they got it right. The new 4Runner handles great."
Shabetta said:He asked how does he know if his truck has it, not what it does.
All he asked was how to know if he has it, why give him an essay??? I did add something positive, i put the thread back on track where it was supposed to be, that ok with you??? Dont be mad because you cant read and wasted your time with information he didnt need.r32 said:If he doesn't know whether or not he has it, there is a good chance he might not know how it works either. Plus, the diagrams should help him identify things if he gets under the vehicle.
Are you his official spokesperson? Why respond if you aren't you going to add something positive to the discussion? Nevermind, I don't care to know your answer.
I understand this, he didnt post the pic of the pumps btw.......and still the question hasnt really been answered.........there has to be a better way than getting underneath the truck and looking for a pump???jeremysoca said:I think the diagram r32 included would help in identifying if you have the system or not (hence the picture of the pumps). This forum is around to help educate people which I think r32's post accomplished.
jeremysoca said:What other way can it be confirmed? If you want to know if you bot a v6 or v8 youll have to lift the hood. I guess if the window sticker is in the glove box he will be able to tell.
I think its a good idea to get under your truck to familiarize yourself with whats under there ie clearance issues while offroading, wear and tear items.
I really do appreciate it when other forums members take the time to reply to posts (esp mine).
Uneek said:If your 4Runner V8 Limited has the rear air suspension, it has X-REAS. The rear air suspension option is only available on V8 Limited 4Runners. However, it is possible to have X-REAS without rear air suspension.
AmbideXtrous said:Why is this the case? You're saying if you have a Limited with the air suspension then you automatically have XREAS. Do you HAVE to have XREAS for the air suspension to work or do they just come packaged together? I thought they were separate systems entirely.
Uneek said:Yes they are packaged together from the factory, but AFAIK, they are seperate from each other. I don't believe you need rear air suspension for X-REAS to function or vice versa, i.e. independent systems.
