Xenon Depot LED DRL with the money?
Daohaus
I don't like the yellowish incandescent light that is in for our DRL but the way LED's with you can't just simply plug in a bulb. Saw this xenon Depot solution and thought cool I'll check out out? Then I saw the price $180!!
I like having LED but at that price is it truly worth the spend?
Thoughts?
Thoughts?
Im running those in my High beam, super bright ! But I have also disabled the drl.
I have the last version in my high beam. I also have their led headlights. I have had them for two years with no issues. They are very bright. I kept my daylight running light. They are good company and have always responds promptly to me and are regulars to the forums. There is a lot of options for lights out there now a days though too.
Thoughts?
I have that setup. Earlier models had flickering issues in the DRL but Xenon depot sent out free replacements so that fixed the issue. No problems since then.
Thoughts?
I ordered the 9005 Bulb with DRL option back in January and I run all the time with these DRL lights on. It works great, steady dimmed light with no flickering... it looks nice too. One thing tho.. it appears to be a small delay , few seconds, from one bulb to the other when i turn them on. I called Xenon Depot to ask and was told that a few seconds delay is within specs so they cant do anything about it. sucks but what can i do. I ordered the H11s too but I am planning on removing them because they get hot and I dont want to risk them melting the housing.... I did not make the hole on the headlight rear cover. Hope this helps.. Max
I have these in my ‘19 LE. I have them with the DRL module. They are insanely bright and I’ve had no issues with them. I think they’re very good. I bid noticed a little flicker once on the passenger side with the DRL. But it never showed up again.
I have them paired with the XD HIDs with the 4300k Philips bulbs. I’m less impressed with the HIDs and often wonder with a newer LED would be better. [emoji2369]
AndiGarage
