Xenon Depot Lights
Snackie
Member
Quick question that I need help with. Does anyone know what other HID H11 bulbs plug into Xenon Depots light harness? I burnt out either a bulb or a ballast and they are back ordered out of bulbs for 4-6 weeks? Looking for 5000K
Thanks in advance,
Thanks in advance,
Hi [MENTION=153747]Snackie[/MENTION], EDIT!
I'm running OPT-7 HIDs (low-beams)! If I loose one of my low-beams; (let's say the right-side), and don't know whether it's the bulb or ballast... I'll just swap an (H-11) bulb from the Left-side! If it comes on, I'll know the bulb was (EDIT...) "NO-GOOD!"
If it Doesn't come on, I'll swap the ballast from the Left-side, and it comes on, then I'll know that I have a Bad Right-side Ballast; (process of elimination)! Follow(?)!
~rig~ Best!
Thank you….will do. Problem is if it is the bulb, they are back ordered in everything.
Hi Snackie,
...sounds like it might be a good time to check... ebay, Amazon, Walmart...etc, for more resources; a lot of manufacturers move product there too these days...(?) Lol!
~rig~ Cheers! :cheers:
AndiGarage
