XenonDepot HID vs LED, initial photo. (Pics reposted)
I'm getting ready to buy a set of HIDs, but I'm a bit confused with the exact bulbs i need. I know H11, however, TRS offers an H11B which is said for Japanese vehicles. Is this an important issue due to having a 2015?
Just give the guys at XenonDepot.com a call. I think it's just the standard H11 but I'm no expert.
Thanks. I just ordered the XD HIDs with 4300k Phillips bulbs off of their site. FWIW, it looks like you save a couple dollars on THEIR site using code XD15 and get free 2 day shipping compared to the site linked (KBcarstuff) in their sig.
Cool, if you've lifted the vehicle just make sure to re-aim the headlights lower! I may have pissed off a few drivers at first...
Sorry for the late reply guys, but I just saw this thread.
[MENTION=60898]Paragon1[/MENTION] - Thank you so much for the kind words. I'm glad that you're happy with the H11 HID kit. You will notice that the Philips 4300k bulbs will color shift after approximately 100 hours. They will reach color temperatures of roughly 4700k once they do.
The pictures you posted certainly show quite a difference in the light output.... Although, The HIDs really look that yellow compared to the LEDs... Did you find that the case in "real-life," or is more of a camera thing?
[MENTION=56425]etc.[/MENTION] - Enjoy your new lights :)
[MENTION=3054]Lexusbstrdchild[/MENTION] - Thanks for the feedback! It's always nice when a member can comment on a product after they've had it installed for several years :)
[MENTION=125870]stamonkey[/MENTION] - The whine is perfectly normal. It will subside considerably once the ballasts warm up.
Regards,
Steve
Regards,
Steve
They're not quite as yellow in real life but it's noticeable. Given the amount of rain we've had here in Florida I'm kinda liking it. Looking forward to seeing the color shift and will update with a pic once it's noticeable
Regards,
Steve
Out of curiosity, do the 5000k bulbs shift over time as well?
do your lights have a tendency to only have one side come on with these HID? Then having to turn them off and turn them back on for both sides to fire?
I have had couple of toyotas with HID and they seem to all do this with different brands. (camry, solara, corolla, older 4runner) Just wondering if these new 4runners do it as well.
You won't be disappointed with the Philips H16 LED BULB. It's plug+play, and will be a simple bulb replacement. The "problem" with replacement LED headlights is that you get a large void of light right in front of vehicle.. Do some homework before making a decision :)
Steve
So are these Low beam kits plug and play? My wife has an MDX with the jewel eye LED lights and they are freaking amazing. I have got to do something with the lights on my TRDPro.
The HIDs are PnP to a point. You will need to drill a hole (25mm/1in) in each of the bulb covers (correct name?). You may also need to reverse the polarity on a couple connectors. That's it other than securing the ballasts.
I secured my ballasts to the radiator core support. I enlarged the single hole on the top of the ballast using a step bit and secured it using the bolt that passes through from a wire bracket (uniform on both sides). It's very secure and looks nicely done. I wanted to do it a bit differently, but the wires came up short and it would have required removal of the headlights.
I placed an order today from XenonDepot, just because of this thread.
In a few days I'll be installing the H11 Xtreme Kit (5000K, because I like the output to be close to white), and Phillips Crystal Vision Ultra bulbs in the high beams and fogs.
I'll report back with results.
The output of the stock bulbs in the projectors is disappointing.
So what's the consensus on LED vs HID in a '12 (pre refresh)? Seems like LED is more of a plug n play application since you don't have to worry about ballasts...has anyone used Xenon Depots Cree LEDS? I really don't want to spend $160 on Philipps LED headlights
I initially bought some for my headlights, but they weren't bright enough.
I moved them to my fog lamps , and I love them now. For the headlights I went with the Volt hids also from Xenon depot and now the light output is great.
[MENTION=89132]flynnstone[/MENTION] - As [MENTION=128110]Sierra141[/MENTION] indicated, they are not bright enough for headlight applications.
Steve
wayblom
