XREAS question
gfluff
Member
2010 Limited with XREAS, leaking (55,000 miles)
Are the coils and top hats interchangeable to 5100s or 4600s? Found a few conflicting answers...
Thanks in advance!
If you are asking if you can use the stock top hat and coils with 5100s, yes. You will need a spring compressor and you need to understand you are going to remove XREAS completely. A common use of that application is to level the rig.
Thanks for the help. Messed with tundra, taco, FJ, non XREAS 4Runner suspensions, but I did not want to disassemble my friend's XREAS parts and be stuck...
XREAS is leaking and he's due for tires, seems like a good time to lift a little and go bigger on the tires!
leolediola
