Xreas Suspension is getting bouncy
CHRIS240
Lately I been notice my suspension has been really bouncy , I seem to feel every bump on the road . The truck have 40k , everything is stock , from I remember Xreas not suppose to go out that soon , Any one have any Idea ? .
No, the XREAS monotube shocks should not be worn at such a young age. They should last a lot longer. Have you checked your tire pressure lately?? Make sure that it is to factory specs.
How long will the XREAS holdup? Do we have it 'recharged?'?
As long as the monotube shocks will hold up. Bilsteins monotubes last a lifetime, according to their advertisement. Most monotubes last a long time, easily past 60-70K miles because they are more efficient at their job (less heat buildup and simpler operation). If the XREAS shocks are made of high-quality stuff, then i don't see why they can't last past 100K miles and beyond.
If a line is broke, or a shock does fail, is it possible to replace/repair part of the X-REAS system?
I think that you have to replace the other unit also. So, if your driver's side rear shock blew, then you need to also check/replace the front passenger shock.
upanatāt
