Xreas suspension?Limited?
lbrunner
Is there a way of telling by vin or other means if an 06 or 07 Limited has Xreas suspension? I know to look on the frame rails for the line and that canister thing but when looking on-line its difficult. When asked by phone, the salesman doesn't seem to really know, even looking himself. I'm not sure if there are other lines that could be on the limited that would be mistaken for XREAS. Vin probably will not work either right?
Non XREAS limited owners would be a help!
I have an '04ltd w/o xreas. I just changed out my rear shocks and there's no hose connected to them, just the upper and lower bolts. If you have a hose connected to your rear shocks then you probably have xreas.
I thought maybe there was a way to tell without looking but probably not. I guess I'll have to take a chance and drive to each vehicle.
Thanks for the response though!
Don't like the X-eas
I have an '05 Sport w/X-Reas. I had the passenger side shock start leaking. A $600.00 repair under the platinum warranty. the X-Reas is very expensive to repair without the the extended warranty.
I have 60K on mine and the vehicle does not respond like it used to and the X-Reas is "spongy". However, since it is not leaking, it will not be replaced under the extended warranty. I believe the X-Reas is not worth having. I good pair of shocks will do the same thing for you.
workingwheelswnc
