Yakima Loadwarrior "Build"
4ever4running
A while back I pieced together a Yakima Loadwarrior cargo rack and a bunch of accessories for it. I have gotten a lot of positive feedback and questions about how I installed the lights so I wanted to share some pics and some more info for anyone out there looking to do something similar.
First off, here are all the parts/accessories I have installed:
Thule 43050 Complete Tracker II rack system - $50 (BRAND NEW!!) on Craigslist
Yakima LoadWarrior basket, Hi-lift mount, and Shovel/Axe mount - $125 on Craigslist
Yakima LoadWarrior Extenstion - $120 from a local store
Yakima Light Mounts - $80 (~$40 per pair) from ORS Racks Direct
PIAA 520 ATP's - $400 (~$200 per pair) on eBay
48" Hi-Lift jack - $40 on Craigslist
Shovel - $20 at Lowes
Here are some pics of the initial setup:
IMG_0020.jpg~original
IMG_0021.jpg~original
IMG_0022.jpg~original
IMG_0019.jpg~original
IMG_0017.jpg~original
IMG_0016.jpg~original
IMG_0014.jpg~original
IMG_0015.jpg~original
Light Wiring Information
Here is a wiring diagram that I put together for how I wired up the lights.
WiringDiagram.jpg~original
Fist I mounted the lights and modified the wiring harnesses for the PIAA's. I ended up cutting off the white male/female connectors for each light and soldered some 16 gauge wires to the ground and power wires for each light (red=power, black=ground). Then I wrapped the wires in some conduit to keep them organized and make the install look cleaner. I used zip ties to hold the wires/conduit to the rack.
IMG_0004.jpg~original
Before running the wires down the roof and into the engine bay I did 2 things:
1) I soldered the 4 ground wires (1 from each light) together into one common 16 gauge ground wire.
IMG_0005.jpg~original
2) I installed a Sure Seal Connector which allows me to quickly disconnect the lights so I can easily remove the rack if I want/need to. The Sure Seal Connector is great but keep in mind that you have to make the connector yourself. I purchased the connector and required pins from this website: Connectors - Power Supplies - Amphenol - ITT Cannon - Emerson - Glenair - Deutsch - Lemo - Military - Aviation - Medical - Industrial I went with a 5 pin connector (4 power wires, 1 common ground wire) and 10 pins and 10 sockets. I didn't need all the pins and sockets but I wanted to make sure that I had extras just in case I messed up when assempling the plug and pins. Also, you will need a pair of "open barrel crimping pliars" in order to properly attach the pins and receptacles to your wires. I couldn't find them at any local store so I ended up ordering mine from here: HT-225D Full Cycle Ratchet Crimping Tool with interchangeable die set HT-225D
The specific model numbers of Sure Seal materials I used are as follows:
Plug: 120-1841-000
Receptacle: 120-1839-000
Pins: 030-2196-000 (or 001)
Sockets: 031-1267-000 (or 001)
IMG_0018.jpg~original
Then I ran some wires from the roof into the engine bay. I chose to run the wires down the passanger side A pillar because I already have a gauge pod on the driver side A pillar and I didn't want to have to run more wires down that way. I removed the end cap on the facory roof rails and pulled out the yellow plug. This is a perfect sized hole to run my 5-16 gauge wires. NOTE: Be sure to use some silicone sealant on the wires and the hole when you are done or you will have water seep through the headliner and into the cab!
IMG_0007.jpg~original
In order to access the hole from the inside I just had to remove the 3 "oh s***" bars and some of the to trim pieces. Once the trim pieces were out of the way, it was pretty easy to run the wires down the A pillar.
IMG_0011.jpg~original
IMG_0012.jpg~original
IMG_0013.jpg~original
Then I drilled a hole in the firewall to run the wires into the engine bay. Be sure to use a rubber gromet to prevent any water from coming into the cab from the engine bay.
IMG_0034.jpg~original
Then I mounted the relays where I wanted them and attached the ground wires to the body using self-tapping screws.
IMG_0028.jpg~original
IMG_0029.jpg~original
IMG_0032.jpg~original
Then I soldered 2 of the power wires coming from the lights to each relay. I soldered the 2-12 gauge power relay wires together and ran 1 common 12 gauge wire to the battery. I soldered the 2 light switch ground wires together and ran a single 16 gauge ground wire to the switch. I soldered the 2 light switch power wires together and ran a single 16 gauge power wire to the switch. I kept the common 12 gauge power wire, switch power wire, and ground wire all together and put them in some black conduit.
IMG_0030.jpg~original
IMG_0031.jpg~original
I soldered a new 16 gauge "light switch power wire" to the common 12 gauge power wire and ran the single 12 gauge power wire to the battery. I did it this way so I would only have one power wire connected to the battery, because I already have a couple of other wires connected to the battery and I wanted to keep it as clean as possible.
IMG_0035.jpg~original
Finally, I ran the 3 light switch wires through an existing hole in the firewall and attached them to the switch
Very nice work. Is there a disconnect by the rack for the lights if you had to or wanted to remove the rack for any reason? I guess adding a connector shouldn't be a big deal if you don't have one.
Thanks! Yes, the SureSeal connector allows me to unplug the lights so I can remove the rack when I want to.
Updates...
After driving around with the initial setup for about a year, I made a couple of changes:
1) I really didn't like how high the lights sat on the rack so I looked for a way to try to lower them...after some research I decided on these: Amazon.com: PIAA 74000 7/8"-1.25" L-Bracket, (Twin Pack): Automotive
They are PIAA universal tube mounts that will fit round tubes from 7/8" to 1.25" so they fit on the lower support bar of the Yakima.
Before:
The total height of the rack with the old mounts: 12"
IMG_0403.jpg~original
IMG_0404.jpg~original
New mounts:
IMG_0406.jpg~original
IMG_0405-1.jpg~original
In progress:
IMG_0407.jpg~original
After:
IMG_0416.jpg~original
IMG_0417.jpg~original
Total height of the rack with the new mounts: 7" for a total reduction of 5", much better!
IMG_0411.jpg~original
IMG_0412.jpg~original
2) I saw a thread where a guy had a much better SureSeal weatherproof plug and receptacle that is mounted flush to the roof and secured with a rubber gasket and screws, so I replaced mine with the same setup. I love the new setup, it is a much cleaner install and provides a much more reliable waterproof seal.
IMG_0414.jpg~original
IMG_0415.jpg~original
For anyone interested here is the website for SureSeal: Sure Seal Connectors Are Sealed Connectors but you can't order parts from them directly, so I orgered all of the Sure Seal pieces from here: Connectors - Power Supplies - Amphenol - ITT Cannon - Emerson - Glenair - Deutsch - Lemo - Military - Aviation - Medical - Industrial.
Here are the part numbers for everything that I used:
- 8 circuit flanged plug: 120-8552-305 (I had to get an 8 circuit plug because I have a total of 5 circuits (4 power + 1 ground) and the 8 circuit plug is the smallest one that will fit everything.
- 8 circuit receptacle: 120-1866-000 (I ended up ordering 2 and filled one with blanks to keep the connection waterproof when I don't have the Yakima rack on)
- Boot: 317-8657-002 (boot for the receptacle)
- Mounting plate: 066-8516-002 (top plate to secure the flange)
- Nut plate: M85528/2-18A (bottom plate to secure the flange)
- 6X Mounting plate screws: R440-1/2 (You only need 4, but I ordered 2 extras, and they definitely came in handy because I stripped one during install)
- 20X Wire hole fillers: 225-0093-000 (used to fill in the blank circuits that are not used to ensure that the plug remains weatherproof, again I ordered extras)
- 10X loose pins: 030-2196-001 (I ordered extras)
- 10X loose sockets: 031-1267-001 (Again, I ordered extras)
3) When I replaced the SureSeal, I had to completely re-do the wiring from the lights to the plug. So, while I was at it, I added some quick disconnects right after the lights in case I need to replace a bulb or remove one for any reason.
IMG_0408.jpg~original
IMG_0410.jpg~original
I am much happier with the new position of the lights and the new SureSeal! It looks much better and the install is cleaner.
great write-up, thanks!
which silicone sealant did you use for those wires through the hole, and how well has it held up to the elements so far?
Glad I could help!
I used Seal-All, a general sealant and adhesive that you can buy at pretty much any home improvement store. I only had it on for about a year because I ended up switching to the better plug/receptacle, but it help up great during the time I had it on there. Never leaked and held the wires in place without an issues.
NVBASSJUNKIE
