Zero Point problem
Paulie6909
hey i'm having problems...every time i goto do the zero point, the VSC trac light doesn't flash, it just stays on, i turn the key off and back on it then both trac lights are back on
If it doesn't flash a step in missed in the process. Even with mine having a hard code it still flashes, just doesn't take. Find someone with a TIS to get more info from the ecu
Well I got both the vsc trac and abs blinking, so when I turn the runner off and turn it on the lights are off...BUT when I put it in reverse the vsc trac and off lights come right back on...does this mean something is wrong?
Gets the codes read. Post them here and one of the tech guys will let us know the issue.
