How To: Trimming/Cutting Fenders
Troymclure
So after posting a picture of my cut fenders, I had several people ask me to do a full write up on how I did it. So here it is.
1. Youre gonna wanna make a tool similar to the one shown below. Basically it is a skateboard wheel attached to a 2x2 piece of wood. I drilled a hole exactly 2in from the edge of the skateboard wheel with a 1/2'' drill bit. This allows a sharpie to slide into the hole.
photo4_zps6fda03ef.jpg~original
2. The tool can then be used to draw a line on the fender exactly 2'' up, making a perfect cut line. The wheel sits on the inside lip of the fender and the sharpie marks on the outside of the flare. I then used tape to make the line easier to follow.
fenders1_zps00b3f650.jpg~original
3. Now, remove your fender liner. I just ended up ripping it out as I wasn't going to put it back in.
(I dont have pics of this, as I was freaking out about cutting my fenders, and forgot. But its pretty straight forward)
4. Next, you will want to remove the plastic flare from the metal of the fender. There are 3 or 4 bolts that hold it in and a bunch of plastic clips. Once unscrewed, just yank the flare off. Its almost guaranteed you will break every clip, but dont worry, well get to that in a bit.
5. Mark off a line to cut on the metal fender. This cut doesnt have to be perfect as the flare will hid it. Just make sure to leave about 1'' to the holes where the flare mounts.
fendersinprogress_zpsbebeb455.jpg~original
Heres the saw I used. Its a little air saw I got from Harbor Freight for $10. It did the job wonderfully. If you do the same, just be sure pick up some non-harbor freight blades. I got mine at Home Depot. They are normal jig saw blades, with the U-shaped end.
photo5_zps10fd6878.jpg~original
6. Next, after making the cut on the metal, move over to the plastic flare. Follow the tape line carefully and GO SLOW. This is the cut that will be seen. After cutting, you can sand down the edges so its a nice, crisp cut.
photo6_zps9a205ce6.jpg~original
7. Now its time to reattach the flare. I used some nylon nuts that have a square back, and fit in the holes in the plastic flare. You can then take some short #8 sheet metal screws and fender washers and screw the flare back in, without having to worry about those damn clips.
41iIFgRmWAL._SX300_.jpg~original
photo_zps856583d5.jpg~original
8. Finally, hit the inner fender with some black paint, I used some rust stop from Ace hardware. In retrospect I shouldve cleaned the inner fender better before painting, so Ill have to go back and hit it again.
9. You're done! Enjoy your newly cut fenders and the extra clearance. My 285's look a little small now, but they are not even close to rubbing.
Heres some pics of it finished, as well as a closeup of what will show behind the cut. It basically looks just like if you remove the fender liner.
fendersfinished_zps07494ee4.jpg~original
photo3_zps5e1e00be.jpg~original
Pretty clean job there. Looks factory like in my opinion.
By any chance, do you have any close up shots of the 4r without the outer fender on?
Down the road was considering removing the plastic part permanently, even across the doors.
Thanks for the write up man. Are you concerned about the fender well being so exposed now?
Not really. Theres not much up there, and no way into the engine bay, so I think Ill leave it. The only I might do is plug the hole for the factory intake as that is now exposed, and I dont want any water in there again.
I dont. I was so nervous while doing this, I forgot to take a lot of pics. I can say that there is a weird hole in the lower section of the front fender. If you look closely at the pic without the flare on, you can see where I cut that hole in half.
[MENTION=95421]Troymclure[/MENTION], I dont. I was so nervous while doing this, I forgot to take a lot of pics. I can say that there is a weird hole in the lower section of the front fender. If you look closely at the pic without the flare on, you can see where I cut that hole in half.[/QUOTE]
I noticed that, but not worried as I would have to file the rest of the smaller one up also. Just that mounting area would be difficult to shape.
I was more concerned on the natural shape of the flare of the metal part.
Still can't figure out how to do double quote, and remove part of the quote and show up. DUMB TRUCK DRIVER I GUESS.
I'd like to see a 4th w/o the fender flares.
Might be awhile, just things that cross my mind for the future if it happens. My ride will have to take more and I mean MORE manzanita and tree washings on these off road adventures for that to happen. And when it does, I see a rattle can party happening.
The hard part is, where the rear factory bumper line follows the door flares.
Guess that would be another project, custom design rear bumper to follow the non flare look.
From what I remember about the shape, it closely follows the shape for the flare, except for where there is the indentation where the flare mounts. Idk if that helps at all, haha
Subbing to see who else trims. Would love to see a fully de-flared 4th gen!
Ill post up some pics of mine soon since Ive done a few inches from the front....but will be finishing up all of the trimming early next week......also watch out for those razor blades......sliced my finger open when it slipped haha.
Wow my truck looks different, haha. Gonna most likely attempt to trim the rear flares about an inch or so, will report back here if it works
Resurrecting this one. Need to clean up the edges a little more and spray under where the fender liners were.
erinobr2000
