2021 4Runner OEM LED Headlights/Lights Performance and Retrofit
Goose587 posted more pics previously and I just missed it. https://www.toyota-4runner.org/3555712-post59.html
On another note, I tried installing the XenonDepot Xtreme LEDs with DRL driver in for the DRLs so I could get a more white light. For some reason, it goes on full brightness like it's on high beams. Couldn't figure out why it was doing this because the high beam is now all in one with the low beam LED.
First time using a quote so hope this works...
Looking at the wire diagram on Toyota's tech website, it looks like they're no longer using PWM to reduce brightness of the high beams when in DRL mode. Instead, they're just running the two bulbs in series which cuts the voltage in half and reduces the brightness. Not sure how the Xtreme LED driver works, but maybe it was looking for the PWM and since it's not seeing that in the '21s it's running at full brightness.
I am about to order the 2021 led headlights
There are two versions. Can anybody clarify?
There is a small price difference. I am assuming one is Canadian version? What’s the difference between the two?
It looks like the mounting points are all the same.
I will update you guys when I start doing the install with photos and etc
Don't want to steer you one way or the other in case I'm wrong, but look at which models the headlight applies for. The more expensive one looks like it's applicable to the models which have dual-high and low-led projectors: Nightshade, Limited, and Pro. Not sure what the canadian one is for, but it might not have the dual-high/low LED projector.
Anyone with a '21 Limited, Nightshade, or TRDPro willing to take some voltages for the wires going into the low beam connector on the headlights?
I've been digging through the wiring diagrams and repair manuals on https://techinfo.toyota.com/ and I think I've figured out how the '21 lights work. Only thing I'm not sure about is the voltage that the ECU is supplying to the low/high beam LED module and the solenoid for the low/high projector shade.
There should be wire loom with 3 wires going into a 4 wire socket on the headlight. I think the wire colors are Red, Blue, and Black. While the truck is running (engine on, but in Park), I'd like to know the voltage of:
Low Beams On:
Red to Black voltage
Blue to Black voltage
High Beams On:
Please don't do this unless you're comfortable testing wire voltages. Don't wreck your truck or hurt yourself. :)
I think the voltages should be around 12 Volt, but there's a new LED driver module in the '21 ECU that supplies this current so I'm not sure if it's 12 Volt or a little higher like 14 or 15. For retrofitting these headlights to an older truck we'd want to match this voltage to get full brightness out of the LEDs, but also not over drive them and burn them out.
Once I finish figuring out the wiring for the new lights and how to retrofit them on an older truck I'll post some info here.
There might even be potential for '21 models without the bi-low/high LEDs to make them bi-LED, but to know that we'd need more photos of the wiring on these models. It might be a long-shot, but the lights could be wired for the bi-LED function from the 4-wire plug to the projector, but not be using the solenoid wire which is what needs to be activated to move the high beam shade up for high beam mode.
Low Beams On:
High Beams On:
Haha, I am doing the same. I guess it’s a race to who does them first at this point. lol I was one of the first to retro stock Lexus hids to a 95 accord back in 98. lol good luck. To the best man wins!
Who is in for a wiring harness. I found a guy that made them for Tacos and he's in "I'll take a look" mode, but I'm sure if I said "you can sell 10 in one shot" he might prioritize it a bit higher.
I looked at them compared to my truck at the dealership. There is no comparison. LEDs are way brighter with broader coverage and better reach.
It's exactly what we all want.
I'm in for a set.
I think you are right on - only one of those has LED for high and low beams, so presumably that's the one you want.
Canada has different laws around DRLs, so if you don't live in Canada, prob want to stear clear from that one.
I'm in for a set.
Update on that for people that chimed in. I've talked to three separate people that either have made harnesses for Taco LED retrofits or that made other wiring harnesses and there was some interest but no evidence of doing anything about it any time soon.
So looks like our friends [MENTION=176944]PLRBRR[/MENTION] and [MENTION=231803]Axix23[/MENTION] represent our hopes and dreams on this one.
I'm totally happy to help experiment w my vehicle (2019).
Glad I'm not the only one crazy enough to jump into this mod! I've done this sort of thing before too, swapped '05 WRX STi HID headlights into my '05 WRX. That was pretty straightforward, but required a few relays to get 12v, non-DRL-reduced voltage to the HID ballasts. Glad to say they still work great.
Update on '21 lights:
I picked up my lights from Toyota last night and from my initial look it seems like these are going to be an easy swap other than the wire harness. Haven't penned out the harness wiring yet, but should have it done this week. I'd love a plug and play harness from one of the guys that did the Tacoma lights, but with a couple relays, wire loom, conduit, OEM connectors, and electrical tape we should all be able to make a retrofit harness pretty easily.
Still would like to know if the '21 supplies regulated 12v or if it's a floating voltage like 14 or 15 that's straight from the battery/alternator. If anyone with a '21 is willing to test their voltages based on my earlier post we would all be really grateful!
Also, I found a couple YouTube videos of a '20 Camry headlight breakdown and testing that I think is at least similar if not the same as the '21 4Runner lights. One of the cons with these lights is the price and difficulty in replacing the LED projector/light module if the LED burns out for some reason. So, seeing that it might be possible to replace the projector down the road is at least a little reassuring. I can definitely understand the comments from others that the non-replaceable LED light is a no-go for them. It bugs me too, but I'm hoping the better light output will make all the hassle and expense worth it.
Disassembly of '20 Camry Headlights:
2019-2021 Toyota Camry LED Headlight Disassembly - YouTube
Testing of '20 Camry Headlights:
How to test a 2018-2020 Toyota Camry OEM LED Headlight - YouTube
If I may ask, how much did the lights run you?
That's definitely a con compared to a simple bulb replacement, but the alternative is either LED retrofits that have crap projection, aftermarket headlights like the Morimotos that are of questionable quality and aren't user serviceable either, or full on retrofits that cost a ton and in my opinion look out of place.
I'm hoping for a "professional" harness not because I can't solder or follow instructions but because I know that someone else is going to produce a nicer product and I don't have the time to screw around with it. Hopefully y'all figure this out soon and we can all reap the benefits. Keep up the good work!
Mine were about $750 each side, but you can find them closer to $700 from other dealers plus shipping. If you can find a local dealer that sells parts online you can usually get a good below-list price and then do local pickup and not pay shipping, that's what I did.
They definitely don't disappear. They enlarge as distances grows throughout the beam pattern and they're distracting as hell. Toyota LED headlamps just can't be compared to the luxury cars I've had in the past with LEDs...oh well.
I think your issue is specific to the 4Runner, not Toyota.
We've had a Prius v and Highlander with LED headlights. No dead spot.
I just got mine too. I have one temporary wired up and lights up just fine. The harness needs to be modified alittle but I used push connectors temporary to test them out.
Will post photos when I get a chance.
Would be great to see some proper OEM LED headlights made available for older 4Runners. Way better than any of the aftermarket junk swaps.
I'm interested in a harness.... shoot, if someone can figure out what's needed, I may be able to help source the parts needed.
The only other issues is the lights themselves LOL
Hey guys, my name is Alex and I do Morimoto conversions to a bunch of vehicles, one of them is the new 2021 4Runners. I have a couple sets of the new LED headlights with matching LED fogs that have less than 100 miles on them and it sounds like some of you might be interested in purchasing them. Since I'm a new member, I cannot post in the classifieds yet. If any of you are interested, send me a private message with your phone number and I'll get in contact with you. This set I'm showing is off a Trail Edition so it has low beam LED and high beam halogen. The only modification necessary was to transfer the low beam connection from the Morimoto to the Toyota, that has been completed already. I would suspect that these should be plug and play now since the morimoto's just plug in to the 4Runners. We have installed a set into a 2017 halogen equipped model without any problems, but your vehicle may vary.
We are charging $1000 shipped for a complete set of headlights and foglights.
Hey guys, my name is Alex and I do Morimoto conversions to a bunch of vehicles, one of them is the new 2021 4Runners. I have a couple sets of the new LED headlights with matching LED fogs that have less than 100 miles on them and it sounds like some of you might be interested in purchasing them. Since I'm a new member, I cannot post in the classifieds yet. If any of you are interested, send me a message and I'll get you my phone number to my shop in Colorado Springs. This set I'm showing is off a Trail Edition so it has low beam LED and high beam halogen. The only modification necessary was to transfer the low beam connection from the Morimoto to the Toyota, that has been completed already. I would suspect that these should be plug and play now since the morimoto's just plug in to the 4Runners.
Actually, I'm used to forums having private messages, but since I don't see that as an option here what would be the best way to let everyone know when I have a set available? I should have 1-2 brand new sets available every couple weeks.
There are PMs on this forum. I can't remember if there's a certain amount of time or posts etc for it to activate for your account.
Anyway, have you test fit any of these on a pre-LED model? I see a mentally logical conclusion about the connector, but the question will be do they actually work??
Also. HOW MUCH???
Also, what shop do you work for?
Also. HOW MUCH???
There must be a minimum amount of posts that I just haven't hit yet.
We did already install a set into a 2017 halogen model and it worked great! I didn't know if I could post pricing with this not being a classified add, but we are charging $1000 shipped for a set of headlights and foglights.
I updated my first post to reflect this information as well
Sorry, let me make sure I understand. Have you modified the lights you are selling to plug into existing harnesses on older models? I might be dense but I want to make sure I read the above correctly.
That is correct, these plug right into the existing vehicle's harness
wwarren702
