torque pro android app
MadCityRich
Last week I picked up an OBD2 bluetooth scan tool - BAFX ELM 327 Bluetooth from Amazon. About $30 shipped. I also got the Torque Pro android app and loaded it on my Motorola Droid 2 phone ($5). My goal has been to find something that will provide good quality gauge information using the OBD2 signals, but have been especially focused on the automatic transmission temperature reading. To date few standard OBD2 readers seem to be able to handle the tranny temp. ScanGauge 2 seems to with some programming, but I wasn't all that interested in the SG2 and the bluetooth seemed like a slick way to go.
This weekend I towed my ATV for some R&R and took the opportunity to see if Torque Pro would give me what I wanted. I was very happy to see that there was a reading of the transmission temperature. In watching the readout, it appears to be monitoring and reporting the trans temp. I watched closely when going up hills, switching between OD of and off, and tracked engine load, coolant temp, rpm, and the trans temp to see how they interacted and to see if what was being reported as trans temp was actually a trans temp and not some other signal.
It appears that Torque Pro is reporting the trans temp and required no special setup or equations. I generally ran at 60 to 65 C (140 to 150 F). When the torque converter unlocked, I clearly saw temperatures rise to 75 to 80 C (167 to 176 F). I'm running a transmission cooler in line with the radiator, for what it's worth. Did most of the trip with OD off to prevent the transmission from unlocking the torque converter. Coolant temps increased with load and was especially noticeable in OD.
My main purpose of this post was to report what appears to be a very successful use of Torque Pro. For the total price (about $35 delivered), I've got customizable gauges and can track the auto tranny temp. I'm now considering getting a smaller Android tablet to take over the gauge and gps functions and get a screen that's a good bit bigger than my phone.
Can't promise how this might work for others. My 4Runner is a 2002, YMMV.
Cheers,
MadCityRich
2002 Ltd
SS 7.2
Konig CS
285/70/17 Duratrac
Tundra 199mm
HD-SKO
other stuff
Thanks for sharing! I had been eyeballing another BT plug in and wondering whether or not to go for it, or just save for the SG2. This makes it easier to decide on the less expensive route, since I've been told you can pull/reset codes with Torque as well.
The price/risk issue is what tripped my trigger to try the BT and Torque Pro. I'm really blown away at the price. Definitely $35 worth of value. I've wasted way more than $35 on gadgets that didn't do quite what I wanted or whose hype exceeded its ability to deliver.
MadCityRich
Nice share. I love that app. Definitely a must-have for anyone with an Android phone on this forum. The track recorder plugin is pretty cool as well.
This is good news. I ordered my own Bluetooth OBD reader and have the Torque app. I'm looking forward to using it. Thanks for the information.
Ha, I was just looking through Google Play and came across this App a few minutes ago and came here to post it. Day late.
Looks like a really good deal.
Would be cool also I guess when you upgrade your phone to just use your old phone as a permanent gauge, looks better than my Ultraguage.
Thank you for posting this. I have the free version of torque and was wondering if the paid version had the trans temp (and that it worked on our trucks). Getting pro now! rep'd
You should be able to do some comparisons with the readout by looking at how other signals are reacting. For example, the MAF and fuel injector readings should allow you to calculate AFR with a little math thrown in for fun. I know I still need to do some setup work in Torque Pro to ensure that all the functions are tied to the specs of the 4Runner, and it's possible AFR needs some setup, too. I'd suggest at least checking the AFR function against the oxygen sensor (the AFR sensor) reading from the exhaust. There should be some correlation and if your AFR readings are in a reasonable range, they are probably reasonably accurate.
Regarding others using this app for auto tranny temp - I think the 1998 and older models do not have an OBD tranny temp sensor. So you may be out of luck. Not sure how it might or might not work for others. I just don't want anyone to assume it's always going to work for them, just because it works for me or a few others.
This is just a word of caution - I'm generally OCD about sensor information and don't assume that the information I'm getting is correct. It's always good to do the gut check. It's also possible that readouts vary from one 4Runner to another, so your own baseline readings are what's important to use when judging fluctuating readouts.
MadCityRich
I like torque. I had it on my android before switching to an iphone. I got my bluetooth reader for 99 cents off ebay. They sell regularly for under 10 bucks on there too.
I have some noob questions regarding bluetooth obd2 readers.
First off does it make a difference which one I buy, looking on ebay there are many cheap, very cheap options in varying physical size. Is there anything in specific I should be looking for or are they all the same?
Also will I be able to read CEL codes?
Thank You! I have needed to purchase one of these for a long time and really appreciate the help!
There does seem to be some difference between BT OBD2 readers. Torque has a list of "supported" OBD2 readers. I picked mine up off Amazon and after reading reviews (see brand mentioned on first post). Other readers didn't have as good reviews. Not sure what may or may not make one better than another. In theory they are just reporting the data, but it's possible there are differences in build quality or which signals are they pick up.
E-bay is fine for a cheap version, but I'd at least check Amazon or other sites with reviews for specific manufacturers.
MadCityRich
I bought the Kiwi adapter for $99 on amazon and it works great. I purchased the torque app because it was rated the best (somewhere I read). I will be getting an iPhone in April and the app that works with the Kiwi is $40...ugh.
I have had Torque+kiwi for a year now and it's great, just plug in the BT and forget about it. Whenever I need to scan, I just turn the app on and I"m reading in no time.
I will say this though, I don't think the fuel mileage is any where close to accurate... not sure why though, it's a pretty basic calculation if you have AF ratios. I also have spent all of zero time looking into it though.
Just bought this app and ordered an adapter. Figured I've wasted $20 on worse lol. Can't wait to try it out! :banana:
I know this thread is old but I'm wondering if the pro version shows voltage and possibly oil pressure. The free version doesn't. I wish torque pro would show what options are available in the free version compared to the pro version.
It varies by vehicle so it's not as if Torque could really do that. If the ECU returns a PID, then Torque Pro will show it. Mine does report battery voltage, as far as I remember, but OIL pressure is a simple idiot on/off sensor that goes straight to the indicator light, with no input to the ECU and thus nothing for Torque to display.
If anyone is looking for a cheap place to purchase a cheap tablet try Laptops, Cell Phones, Video Games, Cameras, Computers - CowBoom.com... Scored my cheap tablet there for this main purpose
1447047
stc6306
