abs/brake issues
charlie corpse
i need help here is my problem i blew my front diff the summer of 13 and after my mechanic change it with one i got from a 4runner grave yard and my abs light was on after that and my brakes were never the same we have bleed and bleed he used a vacuum system to pull the fluid through the lines it worked for a little but abs light was still on now i am currently in the shop again redoing rear end "seal,bearins and full brakes" and he had a issue again with brake being to hard??? we replaced the brake booster but still having a issue and help would be greatly appriecated!!!
Is there a braking issue or is the light just on? Several people on this site including myself have disabled the ABS brakes on our rigs because the ABS on these trucks is less than ideal.
tssawlson538
