MRT Spot Lights on 3rd Gen CBI Brackets Review w/ lots of Pics
Unner
So I wanted to add more lights to my 4Runner, and decided on getting some sort of a spot light to fill in the space ahead of me where my high beams attempt to shine, but can't... I already had a 37" AVEC light bar that does a great job for flood type of lighting and lighting up everything that's relatively close to the front of the truck, but for high speed stuff I still wanted something that would shine a little further. I was initially looking at Rigid Hyperspots, and then I found out about these MRT lights. These are basically clones of the Vision X Cannons. And all I can say about them is that they are amazing lights, especially for the price.
They're less than half as much as the Vision X lights, and shine just as far. According to Chas(he makes these lights), [MENTION=120150]TotalAutomotiveLV[/MENTION], they are rated to shine 900 feet and the Vision X lights are rated to shine 1000 feet. When I was testing these lights I parked in a very large empty parking lot here and turned the spot lights on. I was able to light up trees on the other side of the parking lot, they were at the very end of the beam. I then measured the distance the lights were shining to illuminate these trees. It was .2 miles, or about 1050 feet!!! These lights were also picking up reflections off of street signs over a mile away! They're crazy bright.
They almost make my light bar useless. They shine much much farther and have almost as much width. I really like the color temperature of these lights too. It's more of a 4300k or 5000k light versus the 6000k light bar. The testing that they put the lights through is pretty awesome too. I'll let Chas post more about that if he wants. I don't know all the details, but it involves a lot of deep submersion of the lights in water, freezing them, all kinds of torture testing. I have no worries about having issues with these lights, and even if I would, they have a 3 year warranty.
Installing the lights is pretty simple. The brackets I used to mount them are the CBI ditch light brackets which are a quality product and very sturdy. Installing them isn't hard at all, just follow the directions on their site. Then to install the lights you just bolt them onto the brackets, run the harness, mount the relay and fuse, tuck the wires until you are happy with it and install the switch. I chose to cut off the switch that came on the harness and install an OEM Toyota switch to match the switch for my light bar. This was very simple to do. The only issue with install was the harness was just a tad short to reach all the way across from light to light so I had to extend it a bit, but I talked to Chas about this already and he said it will be revised for future harnesses, it really wasn't a big issue for me though. Just a bit of scrap wire and solder fixed it right up. Depending on your antenna it may touch the light. I have the Tacoma whip antenna mod and mine just barely touched. I put a little vacuum line over the antenna to keep them from rubbing and it's been fine. The antenna doesn't make a shadow or cause any issues with the light.
There are a bunch of different covers available for these lights as well. I have the clear and amber diffused ones. These just basically turn the spot light into more of a flood light. I run mine without the covers 99% of the time.
With the set up of lights on my truck now it's awesome. I have no issues seeing anything out on the trails at night, unless I'm backing up that is... The lights are incredibly blinding. I walked 300+ feet away from the truck and turned around and it was painful to look at so please don't drive with these on when there is other traffic around.
I would highly recommend these lights. Here's a bunch of pictures I took a few days ago of the lights. I'll label them as to what is on at what time.
These pictures were all taken on the same settings. At least these comparison shots that are all taken in this parking lot facing the forest wall thing.
LOW BEAM ONLY
HIGH BEAM ONLY
LOW BEAM and 37" AVEC LIGHT BAR
LOW BEAM and MRT SPOT LIGHTS
LOW BEAM, 37" AVEC LIGHT BAR, and MRT SPOT LIGHTS
I don't know how far the lights are shinning in this pic, but that bit of woods is pretty far away. The parking lot ends at about 250 feet, then there's a creek and 2 baseball fields so it's a good bit away.
Spot lights, no covers
Spot lights, clear diffused covers
Spot lights, amber diffused covers
Post continued in next reply. Couldn't fit all the pictures...
Some daytime pics now, just showing the lights and how they look on the truck.
And my two OEM Toyota switches side by side.
I also took a few videos. I'll have to look over them and see if they are any good and worth posting up here. If they are I'll add them in another reply post.
Let me know if you've got any questions/comments about my set up or want some different pictures.
What kind of halogen bulb are you using or is that HID? Those look super bright for being just "low beams" also with SIN-Japan, where did you order them from? :)
Looks great btw, really wanna shine like yours!
Our resident lighting & electrical mad scientist Chas builds these in his shop. The parts are sourced from all over, then he assembles them with the highest quality materials he can find. There are some overseas companies copying them, but they are using inferior chip sets, have horrible connections and arent IP69K, just IP67.
We offer these at $225 a set, delivered - this includes the CBI brackets, let us know if youd like multiple sets or to order them sans brackets.
MRT LuxMaster 120mm - MRT LuxMaster LED Light Pods - Total Automotive Performance
Here are the published specs
MRT LuxMaster LED Pod - 120MM
Pair of Lights
Assembled in Las Vegas of primarily USA components
3-Year Warranty
25w Luminus Devices LED Chip
850ft x 50ft Useable Light Range
10 Degree Spot Beam
9-32v Operating Input
2200 Raw Lumens
Polycarbonate Lens
IP69K Equivalent Rated – MRT Triple Seal w/ Moisture Block
5200k Light Color
Weatherproof Deutsch Connectors
Hardware & Wiring Harness Included
Wow, really clean install man. I'm stunned by that output!
Thanks man, I was stunned too when I first turned them on too. They're amazing.
Do u happen to have a link to where you ordered them from?
Pics look great
Chas posted a link in his reply. When I ordered mine I just PM'd him and he replied and sent me an invoice via PayPal.
Thanks man. My headlights are Halogen, I replaced the stock bulbs with the GE Nighthawk Platinum I believe. They're better than the cheap stock ones I had in there, but certainly aren't anything to write home about. My other car has a projector retrofit and I've been contemplating one on the 4Runner to get some good lighting for regular night driving in the city.
I did just notice though that I had my fog lights on in the pictures so the more yellow light that is real wide right in front of the truck is from the fog lights, not the headlights.
That output is great, the pictures show it perfectly! Please post a link of where you got them.
Thanks man, there should be a link posted in the reply just below yours.
I forgot to mention in my review that with these lights I am able to park on one side of the Tennessee River, turn on the spot lights and see some green from the river bank on the other side. It isn't perfectly clear where you could see what color shirt someone is wearing or anything like that, but it is still very impressive to be able to light up the other side of the river. If you've never seen the Tennessee River it's not some tiny little river either...
How's the wind noise on them installed?
I might order this setup tonight.
Tell me about the lens for them. What patterns/colors are available? How much does the light output go down with the amber lens?
If you do decide to order, be sure to list your vehicle info in the notes so we can get you the correct brackets!
I was looking around on your site and saw you offered CBI light brackets. Do these come with the lights included at the $224.00 price?
If one had an aftermarket bumper and only wanted the lights to fit in the bumper, would there be anyway buy these without the brackets? The reason I ask is because I plan on getting a Savage Offroad bumper within the next year and would like to integrate these into the design. I understand that I may need to fabricate light brackets to fit if there's not existing tabs.
Diffused, non-optic & euro beam covers available in amber, white, red, blue. There are some KC Hilites and VX covers that work as well. Light output goes down a considerable amount with the diffused amber cover, but normally in low light or dusty conditions that warrant amber covers - you wouldnt want a bright white spot light.
Normally we sell the lights for 225 without the brackets, the forum special adds a free set of CBI brackets. We can for sure come up with T4R special. PM Sent.
Yeah putting my covers on definitely reduces the output, that's why I run without them usually. I need a bright long range spot light most of the time.
They've been on for about 2 weeks now. Still awesome. They've been through many rainstorms and there's no condensation issues. I love these lights!
:high5: MRT tests all lights to insure they are highly water resistant. Good to hear in real world use they are holding up.
They sure are. I clicked them on the other day in a rain storm and it was like driving in snow with your high beams on. All I could see was every single rain drop. These lights are so bright. It's crazy!
I'd be curious to see a beam comparison between these and some 55w HID -converted spotlights (Hella 500's for example). Do you have any video footage of the lights?
wwarren702
