50" curved light bar is the way to go!
regulator213
Finally got around to mounting and wiring up my light bar. I wanted something super bright. I didn't want to spend $150 on brackets for a 42" bar so I decided to go with the 50" and find a way to make my own. I found a metal fabrication shop near me and worked with them for several weeks to find a design that was simple, clean, fairly inexpensive, yet still completely useful.
This is what I came up with...
With them on
Here are some shots of the brackets
I just used some self tapping screws. The brackets line up with the bottom of the overlap in the a pillar you can see on the right of the bracket. This makes them super easy to mount on both sides. They fit great under the weather stripping with no leaks or wind noise.
If anybody is interested in some brackets I can have them made up for you and shipped out. Shoot me a PM.
There is actually some moisture building up under the lens :( The picture up there also has some rain on it from today too though. I'm really bent about that too, I spent the extra money on this one to avoid stuff like that whereas the cheap eBay 32" on the bumper has been on there for much longer and gone through many high pressure car washes with no problem at all.
If you're up for it, take the front cover off and put a bead of silicone around it. I've done this to a couple of lights that I have purchased over the years and water never finds its way in again.
Thanks man, I'm definitely going to do that at some point. I'm just not happy that I have to. That thing has a ton of allen fasteners on the front.
Get some method of security on those bolts. All a thief needs is the right size socket and some wire snips and bye-bye light bar.
Any glare issues w/ the bar being so close to windshield? Glare off windshield or hood? I've got the sport hood and don't wanna be blinded by the cowl or windshield itself hahaha
Why curved vs straight?
I've seen a couple different people with a straight bar and it just looks too wide for the windshield. The curved bar contours to the windshield much better so it doesn't look so out of place. But as far as the bar specs specifically a curved bar will throw light in a much wider patter than a straight bar.
Actually to be honest I was expecting some of that to happen but I don't notice any glare at all. Don't get me wrong, I can definitely see the hood better with the light on though haha. I can take some pics if you want.
The fasterners don't matter much of the gasket they used to seal the lens isn't sealing right. I sealed my bumper light the first day I got it since so many people complain of water damage. Being on the roof you can get moisture in from both ends, unfortunately. The bumper one only gets wet from the front.
But those brackets are very well done.
I'll take your word on it, looks great man!!
Yeah man, I thought about doing it but then what happens if I need to pull it back down for things like having to reseal the damn light from condensation?
Just fix it properly now and then tac weld it. In case you need to remove it, take a cut of wheel and the tac weld of. But honestly its the only way to have some what thief proof. I've had mine welded for few months and so far so good. But my lights never needed repairs or any moisture in them knock on wood. Got mine of Miami off road.
I made my rear mounts my self out of metal angle. Because all aftermarket light brackets are aluminum. And you can't weld steel to aluminum.
Yeah I hear you. I am just shocked that my cheap Ebay one on the bumper has been holding up so well yet this one has seen light rain like once and its leaking...But thanks man! I'm happy with the way they turned out.
Yep, I'll more than likely do that when I find time to fix the bar. Between being a full time student and employed full time as well as being in the Air Force Reserves free time is pretty hard to come by.
The older you get, the more projects come up but the time flys by
