3rd Gen T4R DIY Maintenance, Repair and Modification Videos
One can't ever have enough tools, though some have much more merit than others, as least as utility goes. I have found that I'd rather buy the tool and save time and effort rather than try and make something else work. My brother, well almost the opposite.
I don't know Tim if you got a bad Dewalt DCF883. I am going to be removing a caliper soon and it should be able to remove the 90ft/lb bolts with ease. Still my favorite tool.
I still like it a lot even though it let me down on that caliper. It was definitely a solid purchase.
So I'm trying to check out a lot of these videos and all I see are black boxes within the thread. Please help a noob out!!!
Don't have a clue why you're not able to see the videos in this thread. On my end, I see all of the them.
If you want, go directly to our YouTube channel to view the videos: https://www.youtube.com/channel/UC9EMiD9KPy61kJ6hdXcbjxA
And, if you like what you see, subscribe so you get a notification every time we upload a new video.
Front Differential Replacement
On behalf of "Timmy the Toolman", I am posting our newest addition to the plethora of 3RD GEN repair videos...
This one was a doozy, for anyone wanting to replace both front & rear differentials we now have videos for both.
These diff's were replaced to offer [MENTION=142071]sunsetrunner[/MENTION] ARB locking differentials with a 4.88 gear ratio for his 315's.
Enjoy!
Enjoy!
Jeez that looks like a total pain in the ass, looks worse than removing a tranny!
Great video though as usual! Keep em coming!
I have to agree being as i was there... but i take no credit for the heavy lifting. BUTTTTT its doable!!!!!. & this video tutorial definitely helps with the understanding of whats involved.
Been following along on youtube, even though I still haven't picked up a clean 3rd gen yet, but damn, that one is crazy, wow! Thanks for doing these, amazing work!
Transmission & Engine Mount Replacement
& another 1...
Posting another video on Tim's behalf since he's out saving the world fighting fires in Oregon.
Kudos to Tim. That isn't an easy job. Hope he stays safe.
Yeah it's definitely not a job I'd want to do, going out into strange lands fighting wild fires in the open wilderness, working all day then getting a not so good nights sleep on the ground in the dirt, waking up & doing it all over again, for up to 2 weeks at a time!? Good lord. & then on top of all that, he comes back for his day off & wrenches on other people's trucks literally all day. Tim is truly selfless & is one of the most generous guys I know...
Air Conditioning Recharge
Hey Dudes,
[MENTION=102606]infamousRNR[/MENTION] and I have a video to help you stay cool. If your AC isn't quite cutting it lately and you find yourself braking a sweat driving around in the summer heat, maybe your AC system could use a little recharge to get it back up to snuff.
This is a very in-depth video with lots of information to share. If you get tired of listening to me talk, you can always skip ahead to the parts you really want to see.
Here's the video and Enjoy the Show!
Fuel Filter Replacement
Hey Dudes,
[MENTION=102606]infamousRNR[/MENTION] and I have a video showing you how to safely replace your fuel filter.
Hey Dudes, I installed a B&M 70264 transmission cooler in-series with the stock radiator cooler this past Saturday. I also installed a new OEM radiator and thermostat in the process. Since I was solo on this job, sometimes the lighting and camera angles aren't perfect, but I think the video does a pretty good job of showing how to go about doing this modification/preventative maintenance.
The video is long, mostly because I have a little bit of diarrhea of the mouth at times, but I believe you'll find what I have to say fairly informative if you can stomach listening to me that long. But, if you get bored of listening to me, you can always fast forward.
Here's the video and enjoy the show.
I plan to put a B&M 70264 transmission cooler on my 96 4runner. Naturally, the first thing I did is watch your video where you replaced the radiator and thermostat and added the transmission cooler. It has become standard practice to look for an applicable Timmy the Tool Man video before I begin any work on my 4runner (Can’t thank you and Sean enough for your videos).
I’m not worried about the pink milkshake because I replaced my radiator about 1500 miles ago, so I intend to install the cooler in line with the radiator rather than bypass the radiator.
I think you said in one of your comments on youtube that one of the benefits of installing in-line is that it would help keep the transmission fluid from running too cool. The idea being that the heat from the radiator would keep it warm enough even if the B&M cooler “overcools” it.
In your video you ran the hot fluid from the transmission to the integrated cooler in the radiator, then to the B&M cooler and then back to the transmission. If we want to depend on the radiator to keep the transmission fluid warm enough wouldn’t we run the fluid to the B&M first and then to the radiator so the radiator warms it, if necessary, before it goes back to the transmission? It seems that putting the B&M after the radiator could allow it to cool the fluid to a lower temperature than desired. What do you think?
The 70264 cooler has a LPD (low pressure drop) valve that doesn't open the cooling channels until beginning at 170f and fully opening at 180f so one doesn't have to be concerned with overcooling the ATF.
I have run the external cooler before the radiator for the last twenty years on different cars and trucks with no ill effects.
Drum Brake Shoe Replacement
Hey Dudes,
If you were looking for a comprehensive tutorial on how to do a rear brake job on your 3rd Gen, we've got it right here.
Hey Dudes,
I'm also happy to report that my rear brakes are working great!! :banana:
matisgugle
