This is for demonstration purposes only.
For safety: Apply park brake and have the A/T shifter in park. Choke all 4 wheels in front and back.
AC compressor bearing: 30BGS10DST2 (UPDATE after 7000 MILES: AVOID CHINESE BEARINGS. I BOUGHT the replacement chinese brearing from ebay and it is shot)
OD: 52 mm
Depth: 22 mm
Remove the front skid plate
Loosen 12 and 14 mm bolts holding the AC idler bearing.
Remove the belt
Remove the idler bearing. There is a bushing behind the bearing, be ready to note its orientation on the bolt
1st picture: You can press out the bearing to replace the new.
Idler bearing number 6301 Nachi/NTN
Removal of the compressor bearing
There is NO NEED to empty freon or remove the compressor off the vehicle. (I DID THIS THREAD ON A COMPRESSOR that was removed from a truck)
2nd picture: Remove the 10 mm bolt: impact gun is the best: It will spin just like how the crank bolt spins so be ready to hold the clutch. [HINT: BEFORE you remove the belt, have the ignition ON (engine NOT running), turn the ac on to engage the compressor clutch and then remove the 10 mm bolt)
3rd picture: 10 mm Bolt off
4 Picture: Using a 12 mm bolt to puller the clutch from the compressor: IMPORTANT: There is a 1.5 mm thick washer and keep an eye on where it goes.
5 Picture: clutch removed
6 Picture: 1.5 mm washer shown
7 Picture: Lock click removed
8 Picture: Pulley pulled out. It should come right out with gentle pull.
If you want to remove the clutch coil pack, remove the circlip
shown inside and then remove the wires attached to the coil pack
OD: 52 mm
Depth: 22 mm
Remove the belt
