Mighty Buffalo
turbo/super charger install
I'd like one on how Tim maintains his yard. It looks nice. I am still cleaning up from Matthew at the moment.
Real estate prices in some parts of the country at the moment are nuts, crazy nuts.
I'm sorry, maybe I missed it, do you have a link for the existing videos. I have lots of plans coming up and could use:
Tundra brake upgrade
Sound deadening the interior
Radiator replacement
LBJ replacement
Full suspension replacement
Wiring lights from the roofrack
Timing belt replacement with associated components
Interior disassembly and reassembly
Spark plugs and tune-up stuff
Front and rear bumper removal
I could go on and on and on......point is, this is a great service lots of folks could use. Thanks!
Replacing rear axle seals/bearings.
Adding an E-Locker
E-Locker Harness/wiring
Rear Diff replacement
Rear axle replacement...
See where I'm going? :becky:
I do see where your going. Did you go there yet? I'm thinking about doing the same thing. So how about it [MENTION=120071]mtbtim[/MENTION], you up for an e-locker stock housing retro fit vid? I got the line on an e-locked third with the same gears as my rig. It's got the wiring with it. Some one help me pull the trigger. It's e-locked or air at this point. E-locked will be harder but cheaper.
I did an E-locker retrofit from a 97' 4runner and swapped it in mine...
factory button,
factory computer module
factory wiring.
...... [MENTION=120071]mtbtim[/MENTION] and I also have a slight filter of trying to do videos that will be popular with the masses.... e-locker swap is such a niche market of only US modders on T4R...
although i perosnally would be down to help
Would we be doing it at your place?
Dashboard pull apart, including removal of the power to the automatic antenna, installing new dash light bulbs, etc.
I'd consider taking it your way if your interested. Or if you wanna come out to Bishop that would also work. The thing I'm lacking is a welder. I'm trying to think of other ways to build the housing up and JB weld keeps coming up in my brain. It's probably a really bad idea but that stuff works for almost everything I've used it for. Probably a bad idea in this application though.
When you did your swap did you pull the housing or do it in place? I keep thinking I might not have to pull the housing at all. I can plasma cut and drill from underneath the rig. The hard part would be welding the housing to build it up. Any tips that you have would be appreciated. I can have the third member shipped here for just a bit over 500 bucks. That would include the switch, ecu, and harness. I really need to tell the guy yes or no. I feel like an idiot not to have said yes already.
What welding is needed?
I've done about 5 elocker swaps (getting ready for another one) and it's far easier to take the axle housing off than having it under the vehicle. There's more room to work with. On the last 3rd gen housing I did, I didn't weld the mating surface to build it up and it's been leak free for over 10yrs. With the older Toyota trucks/4Runners (85-95) I did weld up the housing mating surface and grind/file it down due to it having less of a contact surface.
With a steady hand you may be able to get the fork clearance cut with the plasma. You'll probably have to clean it up with an angle grinder afterwards. What sucks is cleaning up the grinding dust. BTDT and hated it..
