Old 01-01-2020, 06:34 PM #1
Jubsz Jubsz is offline
Jubsz is on a distinguished road
3.4L Ticking/tapping Noise
My 00 Limited has recently started ticking/tapping a bit. I've searched around quite a bit and haven't seemed to find anything that strikes me as my issue. I'm mechanically inclined but I do live in a condo and don't really have a place to work on the truck. It is also my daily driver.
The truck has 225k on the clock. I've owned it for 4 years and about 40k miles. About 18 months ago, it did have the Catalytic converter replaced with an aftermarket unit. It has been maintained well overall but does need a few things currently. I am overdue on timing belt/water pump/valve adjustment and it has a leaking valve cover. It should probably also get spark plugs/tune-up. The plug wires are red so I am assuming non-OEM. I recently added about a quart of oil to it after 4k of driving since changed. It was still on the dipstick but a little bit below the minimum line. I do not think that is low enough for concern of rod knock/damage but figured I'd throw it in there just in case. I've used OEM filters and Mobil 1, as did the previous owner. I am hoping to move to a house with a garage this summer so I've been waiting until I can do it all myself. I do have another vehicle I can drive if need be but it is currently put away for winter and I'd rather keep it that way.
The ticking is not noticeable while driving but is very prominent at lower speeds, especially in parking lots/garages. It is barely noticeable when engine is cold but very noticeable when the engine is warm. It is 100% rpm dependent and seems to be coming from the passenger side cylinder bank but is hard to tell. I know these engines tick a bit so I'm hoping that maybe someone recognizes it immediately.
YouTube
Jubsz is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 07:08 PM #2
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light
brillo_76's Avatar
Real Name: Jon
Almost sounds like a knock too. Could be valves need shims and injectors.
Keep an eye on your oil.
This to check :
1] PVC valve.
2] vacuum lines
3] compression check all 6 cylinders.
See if you can pinpoint the exact location of the tick.
Injectors are known to be noisy too but that sounds me more like a valve ticking.
If all that checks out good.
Try locus or some other name brand injector cleaner. [ doubt it's an injector]
You can also jump a oil grade to like 10w 30 or remove a quart and add locus heavy duty oil stabilizer.
If you add locus and it quiets down some you definitely have some engine wear.
Just a few thoughts.
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 01-01-2020, 08:59 PM #3
spartacus's Avatar
spartacus is a jewel in the rough spartacus is a jewel in the rough spartacus is a jewel in the rough spartacus is a jewel in the rough
spartacus's Avatar
Get under the truck and see if the noise is the flex plate. open the inspection cover and check for hair line cracks.
Old 01-01-2020, 10:04 PM #4
Thanks for the suggestions. I'm wondering if I should sideline it until I get this figured out. I do have AAA and a good mechanic I could take it to but he usually takes a while to turn things around. My other car is an S2000 and is away for the winter about an hour away. I'd really rather not pull it out in the winter but I may need to at this rate.
Does this sound like rod knock or something else? I'm getting a little nervous that it may be.
Old 01-01-2020, 10:09 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Its really hard to say exactly what it is. I listened to it twice. I can here that tick your talking about. Mostly rods knock is a different sound. Mostly deeper sounding.
You can get a mechanic stethoscope or use a rubber house to your ear and should at least be able to pinpoint the location of that tick. When you have a location narrowed down. It will help you and your mechanic find out the cause.
Old 01-01-2020, 10:15 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Here is what a flexplate failing sounds like. Definitely worth having it checked via the inspection cover. It seems to be a higher pitched tick though
YouTube
Old 01-01-2020, 10:50 PM #7
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton will become famous soon enough
pluton's Avatar
Real Name: Keith
The noise on the video is not rod knock. Valve noise is "tick tick tick' but rod noise is 'tock tock tock'.
It is, however, louder than the normal "background" ticking sound that my engine (approx. 175K miles) makes when it's completely warmed up.
Mine's manual trans so I don't know about flex plates.
Definitely investigate it yourself or have it investigated.
pluton is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 10:57 PM #8
Yea, it started probably about 2 weeks ago. I'd bet I put over 700 miles since it started but I do think it's gotten louder. At first, I wasn't that concerned and I didn't think it sounded like rod knock. I've gotten more anxiety about it as time has gone one. I don't have much experience listening to valve/injector noise but it just seems to be getting louder. I was hoping that I'd make it to the point that I have a garage and in the summer/fall daily my s2000 while tackling all the 4Runner stuff. I might have to bite the bullet and have a mechanic look at it and probably do the deferred maintenance stuff while I'm at it.
Old 01-02-2020, 12:11 AM #9
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is just really nice T4R2014 is just really nice T4R2014 is just really nice T4R2014 is just really nice T4R2014 is just really nice
T4R2014's Avatar
Make sure your spark plugs are tight.
Old 01-02-2020, 10:47 AM #10
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
Can you hear it from inside cabin? Check out idle to 1200 rpm change for below if you can hear from cabin.
What would you say is the frequency of oscillation?
In line with RPMS but is it 'fast' like the firing of all cylinders or somewhat slower like one cyclinder or one rotation of belts or a finger tap type speed?
2001 Limited 4WD - 324K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 01-02-2020, 11:09 AM #11
Riceye Riceye is offline
Riceye will become famous soon enough
This.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 01:39 PM #12
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough
Real Name: Werner
Personally I have the same noise I think without hearing this in person and it's part of your evap system. Theres a little ticking noise on one of the evap system components and you can feel it pulse in the small vacuum lines there. It's completely normal. It fluctuates with rpm and is really only audible in park or up to 10mph. Sometimes you can hear it on surface streets. But feel those vacuum lines and I'm willing to bet that it's normal.
VernySanders is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 01:41 PM #13
Real Name: Werner
Real Name: Werner
It's a little louder than I was anticipating I didnt notice at first you provided a video. Could this even be a cracked manifold? Sounds like all the crappy fords and chevys that drive by with shotty manifolds
Old 01-02-2020, 01:46 PM #14
jeredcollins's Avatar
jeredcollins jeredcollins is offline
jeredcollins is on a distinguished road
I have a little bit of a ticking noise as well. Isn't there some people that mention the master cylinder is often the culprit behind this noise?? Hopefully someone else can chime in.
jeredcollins is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 05:08 PM #15
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light
Real Name: Jerod
Hopefully I can point you in the right direction and ease your concerns.
1. It is NOT rod knock. Rod knock as brillo pointed out is a much deeper and louder noise. The sound is centered in the block and sounds like two large stones pounding together. Not like yours at all.
2. It sounds like to me it's an injector or Fuel Pressure Regulator that is ticking. Toyotas of old are known to have a very loud injector tick you can hear from the engine bay (my 91 was one of them) and is completely harmless if this is the issue. The FPR is located on the fuel rail on the backside of the engine, looks like a circular object with a vacuum hose coming out about 2 inches in diameter. Get yourself a length of vacuum hose about 3 feet long and put one end where you suspect the noise is and the other up to your ear. Poor man's stethoscope (these are also cheap on Amazon if you want to get one) and helps you hammer down the location of the noise. The injectors can be seen under the upper intake manifold.
3. If the sound is coming more from the spark plug area or on the opposite side of the injectors, so near the valve covers, it's possible it's a valve tick. This can be fixed with a valve adjustment but it's a very involved job that takes a lot of patience. Not expensive but you'll have your engine down for 1-3 days depending if you need valve shims special ordered from Toyota. This is not a "must fix" item though, you can switch to a high quality synthetic and it would most likely go away for the short term. Eventually though you'll start to feel your idle grow rough over time. Once again, not a must fix but more of an annoyance.
Hope this helps ya.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
bit , engine , hoping , noticeable , truck
Engine Tapping/Ticking Noise Lexington 5th gen T4Rs 31 12-27-2019 09:59 AM
Is this ticking/tapping sound normal? pudzley 4th Gen T4Rs 5 01-28-2018 04:11 PM
Tapping noise in engine rosmith2 4th Gen T4Rs 4 04-05-2004 09:33 PM
Rattle/tapping noise '04 SR5 Blackie Problems & Warranty Issues 6 03-03-2004 02:36 PM
03 4runner ticking noise (lifter noise) jgball Problems & Warranty Issues 1 12-18-2003 12:49 PM
