Dom8706
So my left rear tire is noticeably sticking out more than the right rear tire. A good inch or so. Bought the adjustable bar to fix it. No brackets. Followed the instructions and the left rear is still noticeably out further.
I'm wondering if I can take the bar off and lift the rear and set it back down to center the axle and adjust the panhard bar to fit whatever that would Messure.
Would this be OK to do? Centering the axle is the whole point of the adjustable bar right? Would anything else be causing the left tire to pop out like that?
Also my mind is telling me to shorten the bar to pull in the left side more but that would make the adjustable bar shorter than the original. Is that correct?
I did follow his directions correctly and used the more accurate "cut an inch" methard.
Bonus question. When I add an aftermarket bumper and tire rack in a couple of months would I have to re adjust the bar again to make up for the added weight? About 200 lbs.
Thank you guys!
Thank you guys!
