The 3rd Gen All Questions Allowed Thread
Status
Not open for further replies.
mysterious coolant loss, 99 sr5
been loosing a little coolant at a time. cant figure it out? no visible leaks, no choc milk oil, burns off a little white smoke at start up only, did the timing belt/ water pump about 40 k ago. it does have an oil leek from i guess the driver cam seal so im going to do the timing belt job again. no misfires or codes. any suggestions where to look? could it be a slow head gasket leak or a cracked head? how would you diagnose that. had a mechanic pressure test it too...nada!
mysterious coolant leak
slow coolant loss cant figure it out, no cj
heck engine, no choc milk, no puddle, some white smoke at start up???
Anyone know where i can get SPC bushings 25466 (the poly specride ones), or has anyone made 3d printed tpu ones yet?
I really dont want to upgrade to the xaxis ones as they seem to be less reliable, and lots of mud and sand in pnw. I am located in canada so
Howzit,
Just installed a new radiator into my runnah, now after I noticed that while on the highway going 60 or over, my gears don't shift (automatic) or while going 60, my rpms ride at 2500-3000. It usually rides closer to 2000.
Any ideas what could be wrong or is it normal or something?
1997 4Runner SR5 with 370k miles. :fear:
Hi all,
I bought my 3rd gen 4runner (1997 V6 4x4) last year as my first truck for $3,500. As someone who's learning how to wrench a vehicle, I figured it would be perfect as my father had owned a 1997 4Runner limited back in the day and has only said good things about them.
Something I had overlooked in researching these, rust. I've never owned a vehicle built before 2000 so I assumed it wouldn't be too much of an issue as long as the frame wasn't infested with holes.
So now, I am currently losing my mind over some rusty old bolts and would like to hear from other owners of rusty runners, how did you deal with extracting stripped, corroded, rusty bolts? I can't seem to get my skid plate off to get to my starter, same with the brake line brackets to get it through the wheel well.
Sent from my Pixel 10 Pro using Tapatalk
Status
