Who posted the trick multi-accessory battery clamps?
Endlessblockades
I saw a picture somewhere here (although it might have been someone's IG Story - sorry if I'm confused) of a pair of trick terminal clamps that appeared to be machined from a block of stainless steel that had about 6 threaded accessory connection points on each clamp. I am going to be adding some additional powered devices and am starting to have a rat's nest of wires on my current clamps. Does that ring a bell, anyone?
TY
Not sure what you are looking for but I keep plugging these because I think they work and look great.
SDHQ Built Billet Battery Terminal Upgrade Kit
Yep saw those. Looks like a nice kit with all the fasteners, etc.
Kinda $$ but I'm OK paying for USA made stuff when possible.
Copper or aluminum? What do you think is better? Thanks
opinion.... i don't think it matters much at this thickness. aluminum alloys generally are far less malleable and thus i suspect any threads will be more durable. if the copper fittings are actually steel with copper plate, meh, just go aluminum so you don't run into rust issues.
Thanks a lot.
