Speedbleeder for Clutch Slave?
Check if your original caliper/wheel cylinder bleeder fits the clutch slave. It would be a safe bed to get a matching bleeder to the stock front calipers (not the smaller bleeder that's on the Tundra calipers).
I'd never even thought of doing a speed bleeder on a clutch slave. Since it only takes a few pumps (instead of tons with the brakes), I can always get the wife to help out for a few seconds. If you are just exchanging fluid (no air in the lines) a gravity bleed would likely work if you are by yourself.
premiumusedautoparts
