LED lighting
sn0wrunner
I want to get blue lighting on my dash board and i was looking at autolumination.com and they have all the light bulbs, but my question is what size is the light bulb/s that you need for the dash board?
you need 3 #194 bulbs for the backlighting. the other misc lights in there, like park, drive, seatbelt, high beam, etc, are #74 bulbs. also check out superbrightleds.com
The illumination just uses 194s? That's cool! I didn't know that. That should make it easy to change my dash illumination. Thanks for the info. :biggrin2:
Ordered the lights from Autolumination.com and installed them last weekend, here are some pics! Thanks for the Info!
That looks awesome! You are making me want to do that to mine. I'm going to figure out what headunit I want to put in it first then change out the bulbs to match. :bigok:
3 #194's for the Speedometer, RPM, fuel gauge, and engine temp. For the shifter light just 1 #72. Also 1#72 for the glove box and 1 #72 as well for the ignition light. So you need 3 #194's and just about every other bulb are #72's. Im not sure if there is a "brand name" just go to autolumination.com
Sloan said:
how long did it take to get the dash off, the new lights in, and dash back on?
to do just the lights on the dash, it took like a half hour or 45 minutes. it was really easy to do.
