Driver side door won't unlock all doors with Key
NYT4RBlack
I have a 2000 4Runner Limited.
When I put the key into the driverside door to unlock the doors it only unlocks the driver side door.
If I use the key on the passenger door it unlocks all doors.
What is wrong??
Not sure anything is wrong?
To unlock all the doors at the drivers lock- I open the drivers door and hit the unlock button to open the other 3.
I have never seen mine open all 4 with the key but will give it a try and see if it will do so.
I believe the front passenger door is designed to open all 4 at once with the key but the driver's is not-think security-like a carjacking....
mine opens all of them, you have to turn the key twice. the first unlocks the drivers and the second unlocks all the rest.
Corrected-numba1 is correct
numba1runna has it correct
one turn of the key at drivers door unlocks the drivers door only and a second turn of the key should unlock all the rest....
racedirt1 try yours....
