Bandit Runner's Build Thread
This rig continues to amaze me. Such a clean build with great design elements. As good as it looks on the pics, it looks even more awesome in person!
Got a little more done on the roof rack changes today. Welded a new tube section in between what was left of the lower tubes. So now it goes straight across.
Then I welded in the new light mounts. Here is what the 10" lights will look like:
I still need to add the two vertical tubes that will go in between the two lights.
Thanks Ben! Did you ever get a 4Runner?
Nah. After thinking it over we decided that, right now, we needed something that would be easier for my wife to get kids in and out of. Ended up with a '11 Explorer. Not a "truck", but can't complain. It's a great vehicle and the third row has proven extremely useful in more than one occasion. Drives really nice and we got 27mpg on the way to Louisville this weekend.
And I ended up with our '08 VUE, which again, is no truck but still a great rig. It is AWD and does extremely well in the snow. To be honest, I'm enjoying it quite a bit at the moment, so I'm just biding my time and saving my pennies for when it's time to make the switch to a 4Runner. Who knows, if I can hold off long enough, might even be able to consider a 5th gen or GX470 :-D
Finished up the fab work on the revised roof rack. Got the 2 vertical pieces welded into place:
Then I repainted the modified areas:
Just need to mount the new lights, and reinstall the rack.
Roof rack changes completed and lights installed:
Compared to before:
Can't wait to get some output pics of these new lights.
[MENTION=12884]Bandit[/MENTION]Runner, your 4runner is Awesome! One of favorite on this forum.
I like the mod to the roof rack, very well done.
Sorry if I missed it, but what lights are on your front bumper? ARB high intensity?
BTW, I absolutely love my rear bumper (your 1st dual swing out design)!
Thanks
Durwin
Thanks
Durwin
Hi Durwin,
Thanks! Glad to hear you are still enjoying your bumper! No I don't have the ARB lights on the front bumper. I have a cheaper set off Ebay. Eventually I'll upgrade, but $$$$$! I could buy some now, but I'm saving up for a supercharger. First things first.
A few weeks ago in another thread, I mentioned designing a headlight filler panel that would house a Rigid Industries 6” SR series light. The reason I wanted to do this was to clean up the front end of the truck a little. I had four SRQ lights mounted on top of the bumper, but was never happy with the look there – too cluttered. These lights will be much more integrated into the truck, as opposed to just “stuck on”. Also, with the 6” lights, I will get a little better performance.
The lights will aim perpendicular to the filler panel, so they will be pointed slightly outward toward the sides of the road, which will be perfect to fill in the area between my driving lights and ditch lights. I completed the preliminary design last week. Then I had a prototype part 3D printed by @MTD. He was easy to work with and got the part built right away, and shipped it to me. The cost was very fair also.
I only had the passenger side panel built, because I fully expected to make some design tweaks. I cleaned up the part and began test fitting it. You will notice that I had to add some height to the panel on the bottom side, because the SR lights are a little too tall to fit in the panel. I’ll be using the spot lights that used to be on the front of my roof rack, before I replaced them with the 10” hyperspots.
Test fit on the truck:
For a part that is somewhat difficult to measure, I was pretty happy with how the prototype fit. Just needs a few adjustments.
This is the back side, showing how the light mounts:
With the light installed:
From the back side:
Installed on the truck with the light:
Overall, I’m very pleased with how this is coming out. There are a few minor changes I want to make for fitment, and a few flimsy areas that need to be beefed up. Otherwise it is really close. I will make the design changes and have MTD make the final right and left side pieces.
Looks awesome! Looking forward to working with you on the final product.
Sent from my XT1585 using Tapatalk
The only logical conclusion to this thread is you replacing all of your body panels with LEDs. I for one cannot wait.
I got the final headlight filler panels back from @MTD. He used a finer layer height on these and they look really good. This is how they came. All the extra material on the bottom side is the support material that needs to be broken off the main part.
And this is what they looked like after removing the support material, which took me about an hour:
I started sanding them smooth, but that is as far as I got today. I hope to get these painted and installed before our upcoming camping trip in 2 weeks.
Today I test fit the new light panels. They fit great after I had to file down one corner a little that was interfering.
Then I finished sanding them smooth. Here they are all cleaned up and ready for paint:
This is a cool idea, but is it just the one screw holding all that weight in place? I know the other side basically just clips in. Is that going to stand up to vibration?
Mike Sargent
