Cargo net HELP!
g8rdmd
OK, I feel like a complete idiot. I bought a Toyota cargo net (envelope style) from a member on here (great deal, thank you techno :cheers:). How in the heck do I install it? I don't see any pre-drilled holes in the walls of the cargo bay to put the anchors into... Do I really have to remove the panels and drill the holes? I don't mind doing it and would rather not pay a stearlership to do it, I just want to make sure I'm not missing something before I start drilling :shrug:
Thanks in advance!
I just installed a cargo net not too long ago - you do need to drill holes for the anchors as there are not any existing holes back there to use. You will need to pull the back panels out in order to have access when mounting the anchors.
I used a net from a Lexus and only needed to mount anchors at the top and just use the 'd' hooks on the floor to clip the bottom of my net to. Not sure if yours is different.
Yeah at first I didn't look forward to drilling into a panel as there is no room for error ! Just make sure of your measurements and you will be OK.
:cheers: Thanks, steve, at least I know I'm not missing something terribly obvious--I was afraid I was a moron :biggrin2: I will definitely measure twice and drill once. Thanks for the quick reply!
