brian2sun
We've all seen a hundred threads about replacing your steering rack bushings to get rid of slop in the steering and give it a more stable feel. A lot of other threads say to replace you inner and outer tie rods to try to get the same stability. I followed the advice and replaced all that stuff this year and saw a very minimal change in vehicle stability. I did nothing for my recovery after hitting a big bump or a pothole and still felt not nearly as solid as it used to be. I was resigned to thinking if you lift a 3rd gen, the handling will go to crap and there's not much you can do to get it to feel stable like it used to when it was stock.
If your rack and/or tie rods have excessive movement in them like mine did, then they should definitely be replaced. But even though I have no play now, it still felt just as unstable as before. Then I finally got around to replacing my lower ball joints this weekend (which were less than a year old and already on the verge of breaking and killing me because Moog makes sh!t quality parts). I went with Napa lifetime warrany LBJs and the bottom line is this...
Replacing the lower ball joints with good quality parts did 10xs more for my stability than my rack bushings and tie rods combined. It immediately recovers after hitting a pothole now and I just wanted to share it.
