Tire Pressure Warning Light
Jeff Kleb
Yesterday, my son and I went on some errands in my 2005 SR5 and I noticed a light I never noticed before was glowing in my instrument panel. Turns out that it was the "tire pressure" light. I checked all four tires.....no problem.
I figured I ought to take a trip to the local stealership to find out what it could be. I assumed it was a bad sensor or something. They were open Saturday, so I stopped in. Surprisingly, they fixed it at no charge and it only took about twenty minutes. Turns out that my spare was a few pounds low. Jeez!
I never thought that they would have a sensor for the spare, but I guess it does make sense because you'd be sucking wind if you had a flat tire and your spare was no good. Anyway, I have owned and driven cars for almost 25 years now and have never had a flat or deflated spare........especially on a vehicle that is not even a year old yet.
Learn a lesson at my expense, folks.......check the inflation in your spare tire! On a positive note, I like the idea of having a full-size spare instead of one of those little donut thingies that they put in most cars these days.
Next time you have a problem, post it here first. It may save you a trip to the stealer!
Koz
Does anyone know what the pressure range is for the sensors? My light came on this morning and the lowest pressure was 28.5 on the left front tire. I know that it should be at around 32, but does 28.5 trigger the sensor? Thanks in advance :)
I got a 04 cd version for cheap but it is a PITA to access. You have to use the search function in Adobe Reader.
Koz
