DIY MOD: How to make under hood lighting.
Great mod man.....definitely on the list!
I have a 15' roll of the epoxy coated LED strip, I might try and use that. formable and it can be cut down to 12" strips for more mounting options!
does your year not have a under hood light? why not tap into existing under hood light?
Nice job, good write up, beastly light!!:flame:
my year doesnt have it. does yours? did any 4 runners have this?
Years ago (87/88) I knew a guy with a first or second gen 4R that had a factory mounted trouble light on a spool in his truck. That was the truck that made me want a 4R. I'm guessing it was an option at the time.
Sorry to revive such an 'old' thread being a biologist I don't really deal with electricity much hence my little knowledge on the subject. So my question is why do we need an inline fuse holder? And the positive lead goes straight to the yellow connector on the fuse box?
You need a fuse for protection, in case something happens and it can stop the power flow.
Yes in my vehicle it goes to the yellow connector.
Let me know what questions you have so I can walk you thru it.
Thanks I'm waiting for everything to come in ill let you know if I have any questions. Thanks a lot
Finished right as the sun set. Thank you for the write-up!
Okay so this is my understanding of your wiring set up for under the hood lighting. I have everything and I'll be doing tuesday afternoon hopefully. So cut one wire of the mercury switch attach ring terminal and screw it to the metal tab on the hood. The negative wire from LEDs to the other wire of the MS. The positive end of the LEDs down to the inline fuse holder and then to the power on the fuse box with another ring terminal. That's what I got out of your instructions hopefully its right :roll:.
Luis.
Wow, luis, you really made this mod so simple. I managed to take up two posts, whole bunch of pictures, and 1.5 hours wording the post correctly. ... you break it down to 6 or 7 sentences!
I made it complicated and thanks to Luis, he made it simple lol
I can't take credit, you're the mastermind, I just deciphered it for the electricity impaired like myself.
Thanks again Steve!
This Mercury Switch is exactly what I needed for more light in the cargo area only when the hatch is open. Thanks for the direction.
Just installed my LED lighting under the hood mod and love it! In all cost me roughly $40. All thanks to eBay :D
I know this is an old thread, but I totally want to do this Mod...
First off, thanks to the OP for taking the time to share this.
A quick question, I've never used LED strips before. Is there a special connector required from the strip to the wire, or will a basic coupler work?
Thanks
Old thread, new mod for you. It's all good lol.
These led strips are just 2 simple wires, a +/-
Just use the strip, twist together, solder, and tape method.
When you start your mods, always do it with the most care and reliable method. This will help in the longevity of the mod.
