Terminator03
I think we're talking about two different things with the 5100's. If all you do is swap the shocks to get a lift and don't change the springs, I agree it will not make a significant difference in ride unless your old shocks are worn out. If that's the case, you'll get more damping which will give a more controlled ride, but it will not affect the harshness.
I had 5100's on my 2WD for about 40k miles and had them on my 4WD for about 20k miles. In both cases, I also mounted up springs from a 4WD FJ Cruiser. This made for a great ride on the street, although a little harsh at times, and drastically reduced nose dive under braking. For about $550 all in, it was a vast improvement on the street. Off-road, I felt, and others who have done this swap agreed, the the 5100's lack sufficient rebound damping off-road which makes for a very bouncy ride in whoops. I also felt they blew through their travel way too fast on bigger hits off road and would bottom out way too easily.
I have now had the 6112's on my 4Runner for 12k miles, including a four off road weekend trips. On road, the 6112's feel a bit softer than the 5100's, but nothing drastic. It's sort of a, "Oh, that wasn't as hard a hit as I expected from that speed bump," type of thing. To me, as in this is my opinion only, the 6112's with their spring did not make enough of a difference over the 5100/FJ spring combo ON ROAD to justify the price difference.
OFF ROAD it's a whole 'nuther matter. I very much recall the first time I went off road with them (the weekend after they were installed). We were rolling down a trail and there was a tight 180* bend in the trail with some whoops in it. I didn't spot the whoops until it was too late to slow down as much as I wanted and I thought, "Oh damn, this is not going to be fun." I was amazed by how the 6112's just absorbed the hits while I tracked smoothly through the turn. If I had still had the 5100's, I would have absolutely bottomed out the front end and likely gone outside the turn into the bushes.
Keep in mind, this is a comparison between the FRONTS only, and between the 6112's with their springs and the 5100's paired with FJ cruiser springs.
Hope that helps explain the differences as I perceive them.
That’s actually very helpful for me anyway. Of course now, I’m just trying to figure out whether the cost is justified for me going 6112 since I don’t really off-road mine (yet). Part of me is of the mind set of “better to have it and not need it, then need it and not have it” though, and then if I went 5100, I fear I’d be upgrading in a year or 2. Do you think that since I may already have FJ springs, and considering I have the yellow Bilsteins that the 5100s would be an improvement other than the height adjustment? Obviously the 6112 would be because it’s a large body shock with better valving, plus higher rate springs.
