Reset maintenance light
mikestang said:
Just so there's no confusion, that's the same procedure as I posted in my reply which is posted here on T4R.
Here it is in detail for those who can't be bothered searching...
TSB EL002-03 has these instructions:
1. Turn ignition switch to "ON" position
2. Set odometer/trip display to "ODO" mode
3. Turn ignition switch to "OFF" position
4. Depress and hold the Trip Meter "RESET" button while turning the ignition switch to the "ON" position
5. The service maintenance reminder light will:
i. Illuminate solidly for 3 seconds
ii. Blink for 2 seconds
iii. Illuminate solidly for 1 second
iv. Turn off
6. Release the Trip Meter "RESET" button
7. Turn the ignition switch to the "OFF" position
8. Turn the ignition to the "ON" position and confirm that the service maintenance reminder light goes out.
Sooooooooo....is it different on later model 4th gens than on early models? I would have thought not.
Whoops, I didn't even see that html link at the bottom of your post until just now.
Oil change was 14mm for the oil drain and 5.5 quarts . The only pain was the tube under the oil catch in the filter area. That setup sucks... we need to design something better
Maintenence light has been reset!
Thanks everyone
Steve:D
Thanks everyone
Steve:D
Cool. I the future, use the search facility - it is your friend.
So I'm searching this topic because my wife calls me and tells me the maintenance light is on.
I just changed the oil....but is the maintenance light the same as the check engine light??
Does the maintenance light come on at certain intervals to remind you to do some work?
I'm new to 4Runners but not to Toyotas...I have a 1999 lifted Tacoma with 176k miles on the original....umm everything, and no lights come on like this. :confused:
No
Yes - to remind you to change the oil. It's documented in the owners manual -- offhand, I don't remember the mileage that triggers it, but think it's around 5,000 miles and 7,500 miles. The function has two stages -- the MAINT light stays on a bit longer at startup initially (5,000 miles), then it stays on constantly at a higher mileage (7,500 miles).
Double-check the miles to make sure I have them right.
jharris2 said:
No
Thanks for the info....I found the instructions to reset.
4500 miles, it'll flash for a few seconds on startup. 5000 miles, it'll stay lit solid. It's strictly a reminder light based on mileage, not the severity or operating conditions.
no wonder mine's starting to flash longer on start ups. I know how to reset it just in case the dealer doesnt do it. Weird, i don't remember mine being solid after 5000 of no oil change yet on the GX, cuz i've gone over 5k, a little over, and the light just flashes longer and longer as the miles progress w/o servicing it.
Since this light is worthless, and the reset procedure is a pain in the butt. Any way to disable it permanently without opening the dash to remove the bulb?
doubt it. It's almost like that one guy in the other forum I moderate in that was asking how to disable the flashing seatbelt warning light because he doesn't wear his seatbelt. It's not really a safety issue, but in the long run when the car gets older and older, we might appreciate that light when we find out possible problems before they get worse. ;):
The light does not do any thing but light up every 5000 miles forcing you to do the reset procedure. It will never alert you to any problems.
erinobr2000
