Twin ARB Compressor mount location
grapemilk
Has anyone mounted a twin ARB compressor in front of the air box? I pulled out the bracket that holds the power steering reservoir and placed the compressor in there. I would have to fabricate a bracket, and I don't know how i'd be able to get to the bolt heads to attach it. I think I would also have to relocate the PS revision. I like the idea of leaving the area behind the air box available for a possible dual battery setup down the road.
Thoughts about this mounting location? Too much in the "Splash Zone" being so close to the front grill?
~sean
thanks [MENTION=28616]SSt4r[/MENTION], some good ideas in that thread. I still haven't seen a build with the compressor mounted in front of the air filter box.
[MENTION=130595]grapemilk[/MENTION] where did you end up installing the compressor? Just ordered mine in the current group buy and debating where to install. Thank you.
I ended up sticking my compressor behind the air box. Ultimately I think it's more protected from the elements (water intrusion) in that location.
[MENTION=125603]bandi[/MENTION] makes a sweet mount for the 4th and 5th gens.
So you decided to ditch the dual battery setup?
Yes. (but understand a smaller battery can fit in front of the air box)
Oh, didn't know that and haven't seen that configuration yet. Need to do some more research. I was leaning toward placing it in the rear cargo storage area. This tid bit might change that. Thank you!
Here is the shrockworks mount for the second battery, it provides a mount for the AC line and the PS reservoir...
Here is the compressor behind the airbox with a 1 gallon viair tank and arb manidold mounting points..
An overhead shot of both installed in a 5th gen.
Man thats awesome! And all these work in the 4th gen?
:doh: Sorry, I did not realize this was posted in the 4th gen. section...
On the 4th, there is not enough room for a tank... only the compressor... as there is not enough height... :(
I think also that your secondary battery tray is for 5th gens only as well, correct? I intend to relocate my PS reservoir and mount my secondary in the same location, but I think I'll have to fab my own mount. Unless anyone knows of someone making them for our 4th gens...
delislerebecca
