You can raise and lower the seat. Have you tried lowering it?is your head hitting the roof when getting into your 4runner?
I got an 06 sport v8 and my head hits when im getting into it.
im by no means tall, im 5'7" so why do I have to bend and cock my head getting in or I hit the top of the door jam getting in? :noidea:
its a power seat so I will have to play with the buttons again or maybe something is jammed or wrong with the seat then. I played with buttons "some" but it would go forward and back and up but it "seems" to act like its down all the way.
I only had it a week and im still getting used to everything so.......
If I'm not mistaken the driver's seat bottom tilts downward at the rear of the seat, the front of the seat bottom still stays at the same position/height, and the backrest of the seat reclines.
well I did some testing and compared to passenger seat height, its down as far as it goes.
guess i'll just have to get used to it.
maybe the leather seats sit up higher or something or maybe its the sport edition but with my friends sr5 I don't have this same issue, I mean my head comes close, but it doesn't hit if I forget to bend my neck.
im sure in a month or two I wont even realize im bending my neck to get in.
Does the driver's seat adjust upwards?
Just wondering if your seat is not working correctly or maybe there's something jammed under the seat that's keeping it from going downwards all the way, I have a Limited and leather seats and no issues for me and I'm much taller than you, I wouldn't think the Sport Edition would be any different!
I went out and got some approximate measurements on my Limited so you can try and compare them to your Sport Edition seat, from the door sill to the seat edge at center of the seat bottom is 10", from center of seat edge to top of door opening is 30", my seat is adjusted back so that the front top edge of the bottom seat cushion is about even with the front of plastic bolt covers where the seat frame attaches to the floor pan, the backrest of the driver's seat is 10" from the second row seat bottom top edge (I have no way to determine the recline angle/tilt of the seat backrest), this is of course the way my seat is adjusted for me at 6' 3".
All measurements were straight up/plumb and or level.
I'm only 5'11 but it's more torso then legs. My head occasionally brushes the headliner, wish I could have found a no-sunroof 4R for this reason. Seat is down as far as it goes, and I'd rather not recline way back... I'm certainly not sitting up 90 degrees straight either.
I'm expecting to bash my bean plenty when I finally get this truck offroad this summer.
:bash:
