Best place to put a level on truck
drallan
Hi,
So summertime again and I'm looking to do some routine maintenance. One of the items on my to do list is a Transmission flush (at least a couple drain and fills). I have an 04 v8 w/ just over 200k on the clock. I think it was done at 115k because the previous owner bought it certified Toyota Pre-owned, but I'm not positive.
My question is, what is the best way to tell if the truck is level other than eyeballing it? I have a slopped driveway and want to make sure that I can get her level and check all fluids. Trans, TCase, Diffs, Etc.
I was thinking I could just throw an generic level on it somewhere, but wasn't sure where or what exactly needed to be level. Can is just on the floor of a door jam good enough? The roof? Cargo hatch? I know she has a bit of a front rake, do I need to elevate the front to account for that? Is the body level different than the frame? I'm sure I could temporarily attach a level to the frame.
Am I over thinking this?
Thanks,
Yes you are overthinking. But for piece of mind throwing a level along bottom of the frame rail should be close enough for fluid checks.
Hi,
Thanks,
definitely over thinking it! If it looks level, its close enough. They come factory with quiet a bit of rake and that's where the engineers designed it. Go with the eye ball level!
Overthinking but some drives are really sloped. Place a magnetic 6" torpedo level on the pan.
I'd say a level on the frame rail in the center of the vehicle. That's about as level as you're gonnna get since everything is relatively mounted to the frame.
