bmw325_num99
As I recently posted previously, I have been trying to find a way to completely disable my VSC and traction control for gravel road private property fun and hoonery. Yes, you can engage 4wd and the center diff lock to disable these things. However, I like to drift a little and 2wd mode in my 2006 SR5 V6 4x4 4runner is the best mode for that. Unplugging the gray plug on the brake reservoir under the hood did not completely disable my stability control. So, after the investigating discussed below I decided to try something new. I have never seen a write-up on disconnecting the yaw sensor inside the car to disable VSC I unplugged the yaw control sensor located near the shift lever in the center console it and this achieved what I wanted. Now, to make disabling the yaw control sensor quick and easy, I rigged up a switch as others have done with the under-hood, gray, reservoir sensor plug documented here.
http://www.toyota-4runner.org/4th-g...c-abs-without-damaging-factory-wiring-10.html
http://www.toyota-4runner.org/4th-gen-t4rs/112855-how-turn-vsc-trac-off.html
http://www.toyota-4runner.org/4th-gen-t4rs/35392-vsc-off-button-2008-v8-ltd-4runner.html#post299186
However, MY switch would be spliced into the yaw sensor in the interior center console. Here is how I did it in about 1 hour once I had all the materials at hand.
Materials
a) A switch/button/interrupter. I used a basic Ace Hardware toggle switch for testing and will soon replace it with the OEM Toyota VSC switch part #84988-35070
b) Two lengths of wire, each about 18 inches in length, stripped on both ends
c) Wire stripping tool
d) Wire cutters
e) Electrical tape
f) Screwdriver (if needed for toggle switch)
g) Socket (10mm)
h) Socket extension, ideally 6 inches or so or more
i) Socket wrench
j) 2-4 Wire connectors/splicers depending on what switch you use
1. Ensure engine is off, key is out and ignition switch is off
2. Open center console storage bin door by lifting up
3. Unscrew the 2 bolts at the bottom of the storage bin
4. Twist, pull, pry yank the center console surround up a little
https://www.youtube.com/watch?v=uB9li4KjueE
http://www.toyota-4runner.org/4th-gen-t4rs/82996-4th-gen-center-console-disassembly-need-help.html
5. Unplug the cigarette lighter and DAC button plugs
6. Open and remove the vertical flapper door/small storage container in front of the shifter by pulling up on it once it is opened. I pressed my finger against the clips/hinges to get it out
7. Unscrew the 4 center console bolts located on either side of the shifter
8. Pull the center console towards the back of the vehicle, lowering the front of the console slightly to clear the 2 pins near the front 2 bolts.
9. Unplug the white shift sensor plug near the front right corner of the shift mechanism
10. Unclip the two clips on either side of the front/bottom of the center console, near the drivers right shin and passenger left shin. Lift the center console out
11. Locate the yaw sensor in front of the shift mechanism. Mine was labelled “yaw sensor” or similar
https://drive.google.com/file/d/0B-U46S3GS9ZoQUV2b3dYRElVZWs/view?usp=sharing
12. Carefully slice the surrounding tape/material that shrouds the 4 wires. I cut this material to about 4-5 inches from the yaw sensor to expose the wiring
https://drive.google.com/file/d/0B-U46S3GS9ZoN3V3YkZaMk9TclU/view?usp=sharing
13. Cut the red wire (not the red and black one) which is the second wire from the end. Other wires might work two but you only need to cut one and I somewhat randomly chose the red one and it worked. Here is a wiring diagram I found but I end up not using it.
http://www.toyota-4runner.org/4th-gen-t4rs/100275-service-manual-download-links.html
14. Use electrical wire strippers to expose wire on each of the two loose ends of the now-cut, red wire.
15. Take one of your two lengths of wires, splice it to the severed and stripped yaw sensor wire on one end and your Ace Hardware toggle switch or what have you
https://drive.google.com/file/d/0B-U46S3GS9ZoYkhkZE1tSFhqNkE/view?usp=sharing
16. Do the same for the other length of wire: Connect one end to the switch and the other to the other loose strand of wire
17. Tape the connections back up on all ends so no bare wire or metal is exposed.
18. Pop out one of the blanks on the center console (assuming you have one). If you want to put the VSC off toggle switch in the factory location near the drivers left knee, you could, but you need more wire.
https://drive.google.com/file/d/0B-U46S3GS9Zob1NyaU1seC1jMU0/view?usp=sharing
19. Route the wired-in switch to the blank space.
20. With the toggle switch on (engaged), test the switch by starting the engine. The VSC/TC lights should go off like a stock vehicle.
21. Press the toggle switch to break the circuit (off) and after a second or two the VSC/TC lights and some others should illuminate, indicating these systems are disabled (and fun can begin)
22. Interior assembly is the reverse of removal.
For posterity, my old posts that describe why the gray-wire-brake-reservoir-unplug mod didn’t work for me:
Short Version: In a 4wd v6 2008-2009 4runner while in 2wd, can you SAFELY go to a gravel road/field/parking lot or similar and completely disable VSC? Then, try to get it to drift/spin out under braking/do a 4wheel-drift and see if the ABS activates or the VSC tries to stabilize the vehicle? Let me know, please...can you spin out/drift completely with no input from the computers or are they still trying to take control? You may hear the ABS pump shuddering or feel the vehicle's path being altered by the computers braking one or more wheels.
Long Version: Here is the background. I love sports cars but sold them to try to merely have 1 vehicle. I chose my 2006 V6 4runner 4WD SR5 as my only vehicle so that I can have fun powersliding/drifting/hooning in fields in 2wd so I can still have some fun and challenging car-control situations. It is no BMW but powerful enough and rear drive that I can theoretically have some fun. [Please refrain from lectures on safety, rollovers, etc. I am good to go there].
HOWEVER, as you all know from the many threads on the subject, ABS and VSC prevent you from having much fun at all in 2wd mode. I unplugged the gray connector near the brake reservoir like so many have done and that did indeed light up my dash with all the warning lights as it should. I was even able to slide around some more than normal which was great. Again, HOWEVER, I swear one or more of these systems is NOT deactivated fully; I still feel and hear the ABS pump kicking on while trail-braking (in the sports car sense, not on an offroad trail sense) and while accelerating out of a turn while powersliding/drifting. This was really frustrating me.
Next, just yesterday, I unplugged the small black connector next to the gray one which did nothing. Also yesterday, I unplugged the very big connector on the side of the brakebooster/reservoir assembly, the connector with the sliding clamp that holds the plug in place. The VSC/Traction lights went off and the ABS light and check engine light came on. I thought "great, this seems different then before" and went for another drive. SUCCESS!! There was no sign of VSC/TC/ABS working so I was having a blast until.....
....The brakes started feeling wooden and weak. I quickly realized the brake booster system had stopped working. I am not comfortable driving this way without the brake booster so I am back to square one. My question up top in the "short version" is to see if the VSC disable button on the 2008-2009 models actually disables everything. If so, I will sell my 2006 for a new model.
I did look into some of the mods offered by the members here but there was no certainty that the VSC and ABS would be completely disabled.
Materials
d) Wire cutters
e) Electrical tape
g) Socket (10mm)
i) Socket wrench
