Tales of the Silver Beast: Bluesky 07's Long Overdue Build Thread
[MENTION=751043]Konvik808[/MENTION] - thanks for your kind words. Ignore you? Nah, that’s not what we do. Forum members here and in other ones I’ve been in have helped me so many times that I can never pay it forward far enough.
Found these Moog springs on RockAuto. Looks to be a direct OEM replacement for the ‘05 RWD and has dimensions, so if the interchange part numbers correspond with those for your truck’s rear springs, this height should be accurate. You can check the OEM part numbers on parts.toyota.com. Hope this works out.
Really appreciate the info and link Bluesky. I did check out that Toyota site and saw that the part numbers matched. Now time to find the right rear spring for my front rake! :happy:
hi Bluesky_07! I have been reading your threads for some time now and really appreciate all the info! I finally created an account to say thanks and ask a quick question...
How smooth is the new Eibach suspension setup? I was about to pull the trigger on Tacoma TRD suspension when I saw your praise for the Eibachs. I don't mind spending the money if the ride is smoother!
I have been searching for the most comfortable on road ride since I don't off road much. I figure OEM will be comfy too (compared to my clapped out XREAS) but want a little bit of lift in the front without spacers if at all possible.
Many Thanks!
