Frequently breaking rear sway bar - Any solutions??
earthrealm
So, recently observed my rear sway is broken yet again, i dont wheel, though go offroad infrequently to exercise the 4wd, i have rancho quick lift struts with 1.75inch lift at the front, and 1.5inch lifts at the rears.
am puzzled at the frequent breakage, so my questions are
1. Could i weld the broken sway bar and reuse?
2. Are there beefier sway bars i cud install, as i noticed the sway bar is just a hollow metal tube
3. If the above 2 scenarios are wrong - ie would transfer the stress to the next weaker link. what is the next weaker link that this stress would be transferred to???
4. I am not comfortable running without rear sway bars, cos i pulled off/broke one of my rear brake lines last time, due to too much articulation -
Had a similar issue on a Subaru, yeah I know :ybrick:
Ended up using a oversize 22mm VS 19mm diameter sway bar. Then ended up replacing the sway bar links annually. The increased stiffness really helped handling though.
Regarding yours, there has got to be something going on for two stock bars to fail. I'd look into that before putting another sway bar on.
I have the ADDCO bars on my V8 '05. They are monstrously stiff. They give the truck way more confidence than it is due in corners.
My passengers in the rear seats no longer clunk heads together when driving around, which was why I got the ADDCOs.
They also eat endlinks for breakfast, it seems... replacing another set tomorrow.
However, the panhard bar @jrm recommended is a better place to start than a stronger sway bar, I think.
Update:
Upon inspection, the endlink itself was fine as were the bushings. However, the OEM endlink had actually wallowed out the hold in the sway bar and thus had become loose and mobile in the hole (even though the bolt was tight).
There's alot of force transmitted through the sway bar, so it's no surprise this happened. The shop cut off the (relatively new) OEM Toyota endlinks and replaced them with MOOG links, which do not appear to suffer the design flaws the Toyota endlinks did. I had them add grade 12.9 washers to protect the bar from being ripped up.
The MOOG endlinks have a much larger ball housing with a greaseable zerk fitting. The shaft is WAY bigger. And the bar-end bolt has a nut fitting cut into the ball side of the bolt to hold with a wrench while installing and removing the [much larger] nut.
Which endlinks to buy? atleast on purchase inspection, the MOOG is far superior to the Toyota. We'll see how they hold up to a heavy flogging up some mountain roads and through winters.
If you lifted the rear at the coils but did not extend the sway-bar end links it maybe causing more tension on the bar.
You can use 2nd gen 4runner end links. They are 1" longer, and on the cheap.
A couple other heavy duty versions to be had also.
You could just take the whole thing off, throw it in the trash and simply get stiffer rear springs. I'm not exactly sure why anyone wants a rear sway bar for off road. The entire point of going off road is to let the suspension articulate and the sway bar prevents this.
I Have broken mine as well. I now disconnect it every time I go off-road and reconnect when im doing pavement time. Eventually as DUFFDOG said, ill be getting stiffer springs and removing it all together.
I usually just disconnect the endlink from the body side on top.. remove the bushings fold the endlink down with the sway bar and let it move around.. ive done it several times.. and then easily reconnect it when im done.. DOesnt interfere with anything, under heavy flex it clanks a little bit on the lower links..
this is the lift i used at the rear.
https://www.amazon.com/gp/product/B001GH5PJC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
so would try the option of using 2nd gen endlinks. am thinking of welding the broken sway bar and use it with the 2nd gen end links for a while, lemme see how it holds up
Sorry, I don’t have any info that can help you, but was wondering how you like the Rancho Quick Lift and if you used their spacer in the rear or went with a different set up.
THE ranchos are holding up ok, over 4yrs now and counting, changes the stance of the truck in a few minutes, nope for the rears, i used daystar spacer kit, see below
That Daystar looks like the same/identical rear 1.5" spacer as the Rancho branded one.
On car-part.com you can get that rear sway-bar for $75-$150.
so i have been suspecting for some time that my shocks may be bad, so today, got a used rear sway bar, and the right rear shocks was removed during the installation, i found out that i could depress the shocks by hand using meduim force,
am wondering if its normal for the shock to be that easy to depress, or is it going back already, the shock in question is bilsteins, hence am wondering if the failed shock is contributing to breakage of the rear sway bar???...
if yes, who can recommend a beefy rear shock?, note i have 1.5inch spacer lifts at the rear, and the bar broke near the LHS, ie close to the suspected failing shock
The RS999305 is the Rancho 9000...like the front you have...9 way compression adjust.
Think you can get a pair for just under $200 on Amazon.
My rear sway bar broke this weekend on the trails, thinking about removing it and getting stiffer springs. Does anyone know what would be a good spring setup to be able to remove both front and rear sway bars, or should I just upgrade/replace the broken sway bar?
setup: 5100's, 5th Gen coils, 1.5 rear spacer, 2nd gen rear links.
