Spare tire seized
T4R03
I know there’s been plenty of threads on this however just wanted to know if anyone has gone with the cutting the wire route? I’m going to be going on a expedition soon and would need a spare. My vehicle is an 03 and with Chicago salt that thing isn’t budging any time soon and I don’t mind carrying the spare in my trunk. I want to cut the wheel and tire out. Can I do this by cutting the wire? Was hoping there was a better way than using a cut off wheel.
You can probably remove the winch and cable assembly entirely, I think the access to the bolts is on top of the crossmember. The hard part would be reaching that far up around the tire.
Interesting. Might be able to get through the rim and to the bolt using some extensions and a swivel socket.
Yep - ive had to replace that winch before. I always recommend cranking it down, WD40 for new 4r owners and regular use
you can certainly try to cut the wire then replace the winch. I might also try to see if you can get some leverage above the tire and see if you can get it to break
Don't count on it! I live in Chicagoland and have an '03 and had to replace my spare tire cable with the upgraded chain and it was a major pain to get the old rusted cable assembly off with the spare tire removed, took several hours!
I can't imagine it happening with the tire still up in place.
So I got the bolt loose with a 3/8 extension and a longer 3/8 ratchet. Bolt just spins in place now. Won’t tighten back up and when I go to loosen it the tire won’t come back down. This mean I need a new assembly for sure now?
Someone snipped mine loose in a Chicago parking lot a few years ago. Ended up getting a new assembly and tire, but you should be able to cut the wire without lowering the tire. Just don’t let the tire crush you, obviously.
Sweet. Sounds like this is going to be the route I take. Also sorry about you getting your tire stolen. Not everyone in Chicago is brain dead. Can’t say that about every individual though.
