Timing chain replacement and possible sludge. NEED SOUTHERN CALIFORNIA MECHANIC
ffr2608
Getting the p0016 code, checked all sensors, mechanic thinks chain and possible sludge. Need a new mechanic in Southern California (prefer OC area) Also, what is an estimated cost for chain and I assume water pump? Really appreciate any help and additional advice…..
V6
102k miles…
Thanks….
D
Removal of the 4-bolt cover located passenger side front of the engine's timing cover, and examination of the main chain tensioner extended length, will tell the story. If the tensioner piston is extended more than ~1/2 inch, the chain is stretched. Search here under my username and P0016, you'll see what I'm talking about.
It's about a $3600 job for a shop to do it, with approx $700 of that in parts if you're using Toyota stuff (wholesale price).
I use this shop, talk to James the owner he is very knowledgeable.
