Tail Light Socket Configuration
I have 2006 4Runner SR5 with Crytsal Eyes tail lights. I have to replace both L & R because Crystal Eyes looks to be no longer in business. I bought a set of Brock off Amazon. There's clearly something wrong with the wiring harness on my car. The harness has a 6-pin receptical connector that plugs into the Crystal Eyes. A reverse light receptical is part of the Crystal Eyes tail light.
Looking at several You Tube videos the tail light has either 2 or 3 light socket recepticals.
Am I missing a splitter harness?
My guess is the previous owner had a lighting/ audio shop do the work
Your best bet is to find someone parting out a 4runner or going to a junkyard and cutting the wires/ harness you need and then connecting them end to end to the matching wires in your 4r
Tail light socket configuration
I got more info. Now I need some confirmation.
There is a "socket lamp" (9007560018) which it looks more like an adaptor. See it in the video (How To Replace Taillights 03-09 Toyota 4Runner - YouTube) at the 2:46 - 3:01 times. This is for the middle hole.
Correct?
Now the bottom hole. I believe it's PN 9007560035. See it in the video (How To Replace Taillights 03-09 Toyota 4Runner - YouTube) at the 3:04 to 3:10 times. It houses a 921 bulb.
Correct?
What goes into the top hole?
turn signal uses
90075-60035
main socket for wire is
90075-60057
reverse is
90075-60018
Toyota parts catalog
plug in your vin to verify
looking at your aftermarket stuff, you need the main socket 90075-60057 to connect back to the factory wiring, maybe it fell down inside your truck.
