DS KIT #KT09115BK 4pc lift
Falls
Super Moderator
For those of you who have purchased this kit where is a good place to get it from ? I want a little more lift .
My Xreas is pulled off and I am running full FJ suspension front and rear and thought the 4pc kit would be better since the FJ spring stiffened things up enough that maybe a 6 pc kit with the front preload would be to harsh of a ride. It would actually be 1.5" lift over what I have now so not a huge issue .
Anyone have pic or the 4pc with FJ suspension ?
Yes I know there are better options , but I don't want to get any higher than that , since I'm not going to run any bigger tires than my 265/70/17's. If I go higher then I risk to much as far as mechanical CV 's and such.
Wheelers only sells the 6pc kit with the preload which is fine but I don't want it riding any harsher than it is with the FJ stuff . It's perfect right now , stiff but not bone jarring. This is a daily driver for me . I try to go OR when I can and spacers will handle it fine , but always open for suggestions ........ I don't know how stiff the 6pc kit would make the front ride.
FYI the 4r and FJ kits are the same . I bought a kit from wheelers before , but it's on dreadog's truck right now .....lol. I've got a nice brand new suspension and just assume keep it .
Amazon.
Amazon.com: Daystar KT09115BK Comfort Ride 2.5" Strut and Coil Spring Spacer Kit: Automotive
If you've got Amazon Prime, you can have it tomorrow for $4 more. I threw mine in last week:
Yeah. There is no difference in the suspensions between 2 and 4wd 4runners.
Yes it will also fit 2wd's because the basics (springs and shocks) but the full suspension is different between the two. For example, spindle lifts can only be done on 2WD 4Runners.
Sent from my HTC Incredible using Tapatalk
