Painting brake caliber
TRD04RUNNER
Painting brake caliper
anyone here painted they brake caliper? please post some picture of them. the front caliper look to nice not to be painted so I was thinking of painting it red or sliver to match the sliver trim on the SE.
I painted mine black. I had actually bought red, silver and black, but just went with the black. I think the red would look cool, but I see too many Hondas around with red, so I didn't want it to look like I was trying to "Fast and Furious" my truck. I think the silver would look really good, but I just decided to go with black.
I usually don't attach threads to other sites, but here is a thread on this topic with some pics.
http://yotatech.com/showthread.php?t=18427&highlight=caliper
Also, if you do a search here for calipers, you will find some threads.
Thanks, momo i just order a sliver G2 Kit for my caliper $29.99 ship at hubcapplus.com. I use the G2 brush on brake paint kit B4 and it's work really well! I think it's the most easies and best kit out their for painting your caliper. It will make my brake look a lot better when I get my deep six on..:D
The easiest thing I did was to use aluminum foil to help mask the rotor. Since you are brushing it on, it won't be so bad, but it might help a little. Post some pics after they are done.
Definately post some pics when your done, I'd like to see how that looks. For some reason I couldn't see the pics in the Yota Tech forum. I was thinking about doing mine silver or black but with all the Honda rice-boys around here I have been putting it off.
That does look good, a little more sporty look to it. I like your running boards way better then the OEM's too.
I'm adding my full install write-up for anyone that wants to try this on their 4runner, or any other vehicle.
G2 Painted Calipers
This Project took me about 3 days total. This mod is not difficult, but is a little time consuming and tedious if you want to ensure a quality job.
Some have chosen to grind down the casting marks on their calipers before the G2 system and others have not. It looks good either way and is a personal preference. It all depends on how much time you want to spend. If you want your calipers to look smoother like a profressional powder coat job, then you should grind. Grinding will give you that "Porsche" smooth factory caliper look.
The materials used are as follows:
- G2 caliper paint kit. Red = $31.00 on sale (www.decalgirl.com)
- Bright silver metallic "S2000" logos = $11.99 (www.decalgirl.com)
- 2 3/4' wide Artist brushes = $2.99 each (Ben Franklin crafts store)
- 1 small pointed Artist brush (for more detailed/hard to reach areas) = $2.99 (Ben Franklin crafts store)
- 2 Hefty Trash Bags = .05 Cents (Walmart)
- 1 Dremel #953 Alum. Ox. Grinding Stone = $3.95 (Home Depot)
- 1 Dremel #932 Alum. Ox. Grinding Stone = $3.95 (Home Depot)
- 1 BrakeKleen Brake Cleaner = $0.00 (Included in G2 caliper paint kit)
- 5ft. standard Masking Tape from your basement = Free
Tools used/optional
- Die grinder with wheel. This is a fast and easy way to remove those casting marks in SECONDS! You need to be very careful if you use this tool because if you press too hard, you ding the metal. If you don't have one of these, then the Dreme grinding stones will do the same job, but will take longer. (borrowed from neighbor).
- Generic dremel tool. = $9.99 with 60 attachements. (Harbor Freight)
PICTURES!PICTURES!PICTURES!PICTURES!PICTURES!
First, get your car up on jackstands. For best way to get your car up on jackstands, read the 2nd post here
Picture of my front caliper FULLY grinded down in all visible areas and smooth as glass. (5+ hours total for all four calipers over two days.
I put about 6 coats of G2 on the fronts and 4 on the rear. Instead of mixing the full amount of paint and reactor in one shot, I took 4 parts of paint using a plastic spoon, and 1 part reactor on a spoon into a small can. This small amount let me do 1 coat on all 4 calipers. I then, repeated the above until I got mutiple coats. I probably have enough left over to do one more coat on all the calipers. I'll save it for touch up down the road. If you mix it all at once like the instructions say, you will only have about 3 hours working time before the paint is hard and unusable.
Picture before logos:
Picture after front logos:
I did not put logos on the rear. To my eye, it didn't really look as balanced and I only favor them on the front - they look like they are made to go there....
Some full shots:
TRD04RUNNER said:
hey J that look really nice with the s2k decal on it! to bad they don't make a TRD caliper decal.
The place I got the from (url above) can make anything. They can do it.
look at meeee
all this talk about painting brake calipers made me want to paint mine. Just finished:
They look good.
I need to repaint mine when I get a chance and think I have figured out a way to make a TRD mask for them. I will post some pics when I get a chance to do it.
hey momo..
what's your status on this project? Can I see a profile view of the runner w/ the black painted calipers? All I saw an yota was a closeup. Did you manage to get a TRD decal???
I just found this project... I guess it will have to wait till next weekend. Oh well.
I just painted my calipers red on my black 06' SE! They look awesome and I will have pics soon. I used the Advance Auto high temp caliper paint and it looks great. I put about 5-6 coats on and have received MANY compliments on the calipers. I highly recommend this and cant wait for some TRD stickers to come out so I can personalize the calipers. Next, I plan to put the "trd" emblem on the side with red graphics to match. This is a easy and cheap mod that will get many compliments.
Jason B said:
www.decalgirl.com can make for you. I got mine there.
Jason, I already called them and they no longer make "custom" caliper graphics. BTW, thanks for the Trueflow air filter. I installed it today and love it. I definately can tell it breaths better and we know it filters better. Thanks again Jason and I hope that alot of other members contact you about this great product. Talk to you soon.
paul
paul-
I bought the black VHT paint this weekend, but haven't done anything with it in fear that I'll want the red afterward. PLEASE UP SOME PICS!!!
thanks!
Am I the only one that thinks this kind of thing is retarded?
I thought painting calipers was only reserved for Civic's with seven inch exhausts that you can hear in the next county.
If you want painted calipers go out and buy some aftermarket brand like Brembo, at least then you'd have some class.
The painted caliper thing looks good on the S2000 because its done with some class AND its on fairly open wheels w/ low profile tires. The painted caliper on the 4x4 wheel just looks, well, bad.
I'm sorry I ventured into this thread, carry on with the painting of the calipers :D
wayblom
