Question on emu front springs
herairk
when running emu front springs on bilstein 5100 what setting do you put the shock at...im guessing the bottom but I'm about to pull the trigger on them and just wondering... and to add to my question can you run the 5100 rear shocks with the emu rear springs or i have to get longer shocks? thanks folks
Which front springs (model #)? The 883,884 could be run on the first perch up on the 5100's but I'd recommend running them on the stock/lowest setting of the 5100's - you will still get a lift for sure, yet won't be as stiff as if you used the first perch of the 5100's.
The rears - you can run 5100's with 895E's with no issues. I now run the 5100's with stock rear springs - once again no issues. I've heard people say the stock springs could fall out becuase they are not tall enough - from my experience this would be impossible. I went back to stock springs simply becuase the 895E's gave me 2 inches of lift and I didn't want that much.
I acutally run the stock rear springs with 2 OME .4inch spacers on the driver's side and 1 OME .4 inch spacer on the passenger side. Evens it out a little and gives me just enough lift to still have a 1 inch rake from front to back.
